Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Think you don't need a cage in your fast car, or that you can throw one in yourself?
Old Mar 26, 2013 | 09:02 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
This is why fast cars need well built cages.
http://jalopnik.com/this-is-what-it-...-mph-458689632
Old Mar 26, 2013 | 11:02 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Re: Think you don't need a cage in your fast car, or that you can throw one in yourse
Exactally.
Old Mar 26, 2013 | 01:00 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Thank goodness for the cage, you can't even tell the car is a camaro or what kind a car it was after the wreck. A professionally installed cage can save your life a proven by that piture.
Old Mar 26, 2013 | 02:12 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
the accident was only around 190. the guy couldnt handle the power of the car. hes nearly wrecked it a couple times and he kept adding more and more hp till that happend
Old Mar 26, 2013 | 02:13 PM
Car: 1971 Camaro
Engine: 427
Sounds like so many. Gotta have more power before they can drive what they have.
Just more proof of my point.
If you are going to spend the money on HP, you better spend some on Safety!
Old Mar 26, 2013 | 04:35 PM
DIGGLER's Avatar
also why you should have the proper tires for the speed you will be going. can anybody id the tires on there?
Old Mar 26, 2013 | 04:47 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Exactly what im saying they look like FIrestone Firehawks from the small part of the tread i can seen
from what i remember i've never seen this car do any event with those wheels on it
Old Mar 26, 2013 | 04:51 PM
Car: 1971 Camaro
Engine: 427
Wow.
I know the guys that run bonnieville are pretty strict on tires, if your fast, it's Goodyear land speed tires and that's about it.
Old Mar 26, 2013 | 05:29 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
makes me want to put a cage in my car. i actually watched 2 guys die in a formula 350 when i was a teenager. the car flipped and it looked like a crushed soda can.
Old Mar 26, 2013 | 06:24 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
The car was set up properly by John Harrison of Houston TX. A personal friend of mine since the early 90s, the Driver is experienced between the road surface and the speed he had problems a few years ago you really can't take anything away from his ability.
Old Mar 26, 2013 | 06:28 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the aero on that car is awful. all the power in the world but no time spent in the aero department will make ya pay
Old Mar 26, 2013 | 09:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just like the Silver State Challenge. Cars running at specific speeds need tires rated for those speeds. The high speed runs at Bonneville are no different and many tires in the super high speed vehicles are solid.
Without seeing video of the crash, it's hard to determine exactly what caused it. A tire could have blown out. Something on the car may have failed. Normally if the aerodynamics of a vehicle switches from downforce to lift, something has failed such as a broken spoiler. If you're running those speeds without some kind of rear spoiler for downforce, you're just an accident waiting to happen. That OEM spoiler isn't designed for those speeds.
I feel safer in my race car going down the track at 150 mph than I do driving my F350 in rush hour down the freeway.
Old Mar 27, 2013 | 07:44 AM
Car: 1971 Camaro
Engine: 427
It was not my intent to bash the driver or the builder with this thread. If anything it is to comend the builder on doing a good job making the car safe in the event of an accident.
I simply wanted to use this relevent example to show people who want to build a fast car but think they don't need a cage or other safety equipment as this has come up on here in recent times.
Old Mar 27, 2013 | 09:02 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you bring up a good point Johnny. when do you actually need a cage, and is it safe or needed on the street? ive heard its something to whack your head on, on the street with no helmet. but after looking at those pics,...maybe its not a bad idea?
Old Mar 27, 2013 | 09:11 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Cage worked
Old Mar 28, 2013 | 01:42 PM
83 Crossfire TA's Avatar
Cage needed, sure.
Not throwing it in yourself... I trust what I build more than a lot of the "professionally built" crap that I see at the tracks all the time...
Old Mar 28, 2013 | 03:18 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Wow. Amazing he survived.
Old Mar 28, 2013 | 03:37 PM
Car: 1971 Camaro
Engine: 427
Originally Posted by 83 Crossfire TA
Cage needed, sure.
I agree, I've seen a ton of cages that would never pass tech, and a lot of guys with welders that can't make a good penetrating bead.
Old Apr 1, 2013 | 07:19 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I wrecked my former F350 twice, both times at high speed. I can't say a lot of good things about that truck but I can say that both times I drove/limped it home, while the vehicles that hit me looked a lot like the car above.
-- Joe
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
z28addict8490
Aug 7, 2015 08:48 PM
rsrmoore
Aug 7, 2015 08:44 PM
