Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
headlight swap
Old Apr 23, 2014 | 06:57 AM
demps100t/a's Avatar
headlight swap
I've got an 86 t/a and I'm looking to get rid of the flip up headlights. I've seen a few ideas on here but I was wondering if anyone had seen the polly motorsports t/a. If so is that a kit or any ideas on how they accomplished it?
Old Apr 24, 2014 | 09:29 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Re: headlight swap
Hmm, looks sweet. Honestly it looks like they just removed the pop ups and hard mounted the lights (like on the Camaro). Then added a headlight cover, or some sort of protector. AT least that's the vibe I'm getting from it.
Old Apr 24, 2014 | 10:15 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: headlight swap
Polly motorsport made there own projector headlight buckets, The clear lexan uses duz fasteners for ease of replacement,
Old Apr 24, 2014 | 10:19 PM
Re: headlight swap
that's kinda what I was thinking to. its the bent part of the cover that's got me wonderin. I talked to a glass place and they said they couldn't do it and get it that clear at the fold. I thought about some kind of plexi glass but once again keeping it completely clear at the bend is a problem.
Old Apr 24, 2014 | 10:27 PM
Re: headlight swap
Thanx that actually helps a lot. My computers movin slow so your post came up after my last one.
Old Apr 25, 2014 | 10:40 PM
Car: 1987 Trans Am
Engine: 355 tpi
Re: headlight swap
If you use lexan you can bend it easily, I used a metal brake for siding to bend mine, although mine is not finished yet, Just go slow, a heat gun would make it bend better, You just can't do a real sharp bend.
Old Apr 26, 2014 | 12:13 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: headlight swap
Looks pretty cool to me.
Attached Thumbnails headlight swap-polly.jpg   headlight swap-ghtp-1107-01-1986
Old Apr 27, 2014 | 08:18 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: headlight swap
look through this thread
https://www.thirdgen.org/forums/fabr...projector.html
1992CamaroGirl
Dec 25, 2017 08:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
