Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sheet Metal Coolant Overflow Tank
Old Jul 9, 2014 | 12:05 AM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Hey guys,
As my welding skills are coming along I thought a good project for my car was to fabricate and relocate a coolant overflow tank. Only thing I am concerned about is the material of the tank.
Can they be fabricated from steel or do they have to be aluminum? I would be worried about the steel corroding and contaminating the coolant.
Old Jul 9, 2014 | 01:50 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: Sheet Metal Coolant Overflow Tank
aluminum, stainless, or plastic. i doubt youre setup for stainless or aluminum
Old Jul 9, 2014 | 11:01 AM
WTR388's Avatar
Car: 87 Trans Am
Some mig welders are easy to set up for welding aluminum like my Lincoln 140.
Old Jul 9, 2014 | 12:40 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
That's what I thought, I have zero aluminum or stainless welding experience or equipment do I guess I'll go the plastic route.
Old Jul 18, 2014 | 08:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is there a particular reason water and glycol need a special material over a fuel tank?
I plan on making my own as well from steel and using a (motorcycle) gas tank sealer kit.
Old Jul 18, 2014 | 11:22 PM
Pocket's Avatar
Car: 91 Trans Am
My intercooler tank is aluminum. Uses coolant, so itll hold up
MIG welding a tank will always leave pinholes. Use JB weld or similar to coat the beads for a water tight build. If you want it air tight from the start, it needs to be TIGd
Old Jul 23, 2014 | 09:08 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Something like this needs to be tig welded aluminum .090 maybe .060. Are you just wanting a square/rectangle or something more oddly shaped?
Posted from Thirdgen.org App for Android
Old Jul 24, 2014 | 01:02 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Why not just go to Canton website by one for hundred bucks
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
codeysabatini
Nov 10, 2015 04:07 PM
gta892000
Sep 16, 2015 12:37 AM
