Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
targa top.
Old Apr 16, 2015 | 07:08 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Transmission: t5 non worldclass
targa top.
This is my targa top build. Making a soft top that will slide open and closed. This is the start.
Old Apr 16, 2015 | 07:10 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
The layout
Old Apr 16, 2015 | 07:12 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
After cut. Used a 4" grinder with a cut off wheel.
Old Apr 16, 2015 | 07:15 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
cut half inch strips of one eighth flat bar.
Old Apr 16, 2015 | 07:19 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
with the roof cut off there is no strength. Needs bracing
Old Apr 16, 2015 | 07:21 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
took my strips and locked it in with the old Bracing.
Old Apr 16, 2015 | 07:25 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
I cut it so the top could be set back in place
Old Apr 16, 2015 | 07:27 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
Targa top = amazing
Old Apr 16, 2015 | 07:31 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Re: targa top.
will post more as project progresses
Old Jun 6, 2015 | 12:26 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: targa top.
What did you do for securing the frame ? Did you add SFC's ?
Old Jun 6, 2015 | 02:10 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: targa top.
Are you making a soft top to go in or using the panel you cut out to make a removable targa.
If you go with option 2 you could probably scavenge some t-top mechanisms to make it lock in.
A buddy of mine did this to his 69 Impala one summer about 30 years ago, there was a lot of beer involved in that one.
Pac J
May 17, 2020 10:44 AM
blackz281le
Jan 11, 2016 07:51 AM
sammy52401
Nov 11, 2015 07:20 PM
jerflash
Sep 22, 2015 09:59 AM
75bike
Sep 20, 2015 09:37 PM
