Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Modded wrap around spoiler
Old Feb 26, 2016 | 09:11 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Has anyone customized a TA spoiler? I'd like to make the back have more of a lip like the early 90's foxes.
Something like this:
Old Mar 1, 2016 | 01:47 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Modded wrap around spoiler
There's a version of this wing already available. One is for sale in the classifieds on this forum. It was a unique wing that looked just like the mustang one in the pic. Not a wrap around but it was a mix of the basemodel wing and the wrap around.
Well not the same after seeing a pic. Here's the classified thread. https://www.thirdgen.org/forums/exterior-parts-sale/729619-85-90-trans-am.html
Old Mar 1, 2016 | 08:07 AM
BrutalGTA's Avatar
Car: 1989 GTA
I was looking for more of a wrap around with a few inch lip off the back of it.
Old Mar 1, 2016 | 10:36 AM
Car: 87 TA clone
Dont think it would look good but down to see you try.
Might be nice to use a camaro high rise and then taper that down like the wrap around hood. I run the camaro high rise on my 87 firebird. It would be easier than fabbing a whole one. Or make a mold of the OEM wrap around and add an inch or 2 to the mounting bases. I just chucked a copy I made of the wrap around, basically layed fiberglass over the OEM wing and then filled it in and mated to the 2 halves together. Turned out ok...but if you do it in half then you can add more to it to make it taller.
Old Mar 1, 2016 | 10:40 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Doing it for looks, more downforce or more drag ?
Old Mar 1, 2016 | 12:49 PM
BrutalGTA's Avatar
Car: 1989 GTA
Probably a combination. I'd like to exaggerate the current lines.
Old Mar 1, 2016 | 12:58 PM
BrutalGTA's Avatar
Car: 1989 GTA
Mecham has something similar, but not a full wrap around.
Maybe something along the lines of this T/A, but square like the original.
Old Apr 10, 2016 | 09:05 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
I'd love to see something like the love child of the Mecham and the wraparound, except wider.
Old Apr 10, 2016 | 09:13 PM
Engine: L03 305 TBI
Actually, that Mecham 4th Gen spoiler is nearly exactly what I was describing!
http://mechamperformance.com/d_docs/s_AEROg4f.html
http://mechamperformance.com/d_images/btaside3L.jpg
http://mechamperformance.com/d_images/rtarear2L.jpg
http://mechamperformance.com/d_images/bta34rear1L.jpg
Old Apr 13, 2016 | 02:23 PM
BrutalGTA's Avatar
Car: 1989 GTA
I posted a picture of that T/A above already, my issue is it follows the 4th gen lines not the 3rd gen.
Old Apr 13, 2016 | 03:38 PM
Engine: L03 305 TBI
Yup ... it's round-ish, while 3rd gen Firebirds are more straight-line-ish.
It would be cool if someone made a spoiler like that, but with 3rd Gen lines, though.
Old Apr 13, 2016 | 11:56 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I know the arguments for and against. I went for it, and don't regret it.
Above 120 mph, the lip is useful. Under, too much drag for normal driving. I am considering both for track days.
Old Apr 14, 2016 | 12:09 AM
BrutalGTA's Avatar
Car: 1989 GTA
You missed it. Go back and look at the TA in my third post. It has an upward lip on it. "Whale tail so to speak."
Old Apr 14, 2016 | 01:39 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
No, I didn't miss it. Probably didn't explain very well.
I want(ed) to add the lip. But the cost of drag for normal driving convinced me otherwise. I run #250 springs in back. I probably will find a damaged wing, and add the lip for use at track days when I get around to it. I won't care about paint matching for a track affair - flat black, maybe. I thought about it here: https://www.thirdgen.org/forums/body...ml#post5187258
I was just showing how good the 4th Gen wing can look - IMHO.
Old Apr 14, 2016 | 04:49 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
3rd Gen MSE has that spoiler
Old Oct 22, 2019 | 08:27 AM
Engine: L03 305 TBI
That's a standard 4th gen wing, not a Mecham wing, isn't it?
Old Oct 23, 2019 | 06:53 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Yes, standard 4th Wing. I fitted it really well, IMHO. I thought about cutting it open, adding some shaped styrofoam, then fiberglassing over to acheive the Mecham look. I still am happy with what I have.
Old Oct 30, 2019 | 08:06 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
this wing looks great on your car.you did an incredible job imo.i added this wing to my car to be a little different.
some people complain about it or dislike it but do not seem do have enough of a memory to understand the wing
that was on the original 1969 trans am.i know the current wing isn't identical to the 69 wing but its close enough
to please me and be different.im throwing around the idea of some tyrol blue stripes and possible tyrol blue
cross lace rims as well.i like the idea of a tip of the hat or tribute to the 1969 trans am.
Old Oct 31, 2019 | 01:17 AM
NoEmissions84TA's Avatar
Originally Posted by 1986BANDIT
i'm throwing around the idea of some tyrol blue stripes and possible tyrol blue
I say YES to that idea.
82knightrider
Oct 19, 2010 03:50 PM
ryan91rs
Aftermarket Product Review
May 24, 2008 08:50 PM
wgripp
Oct 18, 2007 01:29 AM
Blake
Feb 20, 2004 04:55 PM
firewrks
Nov 1, 2002 07:27 AM
