Help Me Find My Rpo Codes?????
Old Nov 25, 2002 | 09:57 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
where would I find my rpo codes at??
Becauce there not in the console or the rear storage compartment can someone help me PLEASE!!!!!!!!
Old Nov 25, 2002 | 10:01 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
If your car is pre-85 then they would have never of had them at all. Otherwise they were probably removed.
Old Nov 26, 2002 | 01:52 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i'm not sure if pre-85 cars would be accurate.
my car is an 84, and i have a spid sticker taped to the underside of the console lid
i checked it against the vin of the car, and the vin on the title, everything matches up.
i think 82 and 83 models didn't get the spid stickers.
Old Nov 26, 2002 | 03:06 PM
Black92Z28's Avatar
In my '84 Berlinetta, I found the build sheet for the car underneath the passenger seat between the foam and the metal support on the seat. It had all my RPO codes listed on it.
Old Nov 26, 2002 | 04:51 PM
OOPPS! Ya you are right 1984 was the first year for the RPO sticker.
Old Nov 26, 2002 | 08:07 PM
MdFormula350's Avatar
so how do you know what an 82 - 83 came with?
Old Nov 26, 2002 | 09:10 PM
They had a metal "cowl plate" which showed some of the main RPO's like CC1 etc. Otherwise you would have to lucky enough to find the build sheet.
Old Nov 27, 2002 | 01:22 AM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
that metal cowl plate was discontinued after 1985, so 84-85 are the overlap years.. cowl plate AND SPID sheet. lucky putzes. Oh well the cowl plate doesn't really show that much info at all. just very few major options related to the body options and the interior layout. and week built.
Old Nov 28, 2002 | 02:42 PM
Rage13's Avatar
Car: 89 Firebird
where is that cowl plate located?
Old Nov 28, 2002 | 09:13 PM
kizz's Avatar
upper radiator support metal plate between headlights, near body hood latch.
slightly closer to the drivers side
will have 4 or 5 lines of codes
Old Dec 4, 2002 | 11:16 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ive had an 82 and several 84's and an 83 and all the 84's have had the SPID label in console and plate on rad support top side in plain view and nothing in the cowl like on other models of car, i dont know on the 88 yet except that it doesnt even have enough room on bottom side of console lid for a SPID label, but the builsheet was under the rear deck carpeting, ive got it right here in front of me right now, so thats all i need,
but yeah 84 was the first year for SPID labels in cars of all models that i know of, and trucks since 1967 in the glovebox glued to lid, all of them got one plus a metal card(protecto-plate) in the owners' protection book in the glovebox
good luck
Old Dec 6, 2002 | 02:34 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
i'm pretty sure that up through the 1990 model year camaro, the spid decal was located on the inside of the center console. i seem to recall a college classmate's 1990 rs having the spid glued to the inside of the console.
i'm thinking the one in my 84 possib;y came loose, and was taped to the underside of the console cover. does anyone else here have an 84 with the spid decal on the underside of the console cover?
i took some engine shots to show someone earlier this week, i'll see if i got a good shot of the metal tag on the core support. if not, i'll post a photo of the tag here over the weekend.
Old Dec 8, 2002 | 05:14 PM
FRDH8R's Avatar
Here's the cowl tag location
Old Dec 8, 2002 | 05:16 PM
FRDH8R's Avatar
and one up close of the cowl tag:
Old Dec 8, 2002 | 11:35 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yes 84 were glues to the lid, from factory
the cowl tag is what i call the rad support tag since is attached to rad support in actuality but on B-body and other body cars its indeed attached to actual cowl of the car body tub, just personal terminology differences, the tag doesnt have crap for info of RPO;s on it anyways no matter what its called
youre pretty much screwed in 83 and older
good luck
hectre13
Dec 11, 2023 08:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Regal105
Aug 23, 2015 03:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
