Are LG4 heads the same as L69s?
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
My friend is thinking of building an AS SCCA camaro and we were chatting over where to find heads. The cars are restricted to 305 iron factory heads(non TPI). Are the LG4s the same as L69s?
Car: 84 Z28
http://www.darklair.com/monte/l69.html
This site says the LG4 has smaller valves... is it untrue? I know it's a monte carlo site but L69s and LG4s should be the same as F bods.
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
There are two 305 heads that can be called the HO head. The first is an early 305 head (casting # 601) that had ultra small chambers (53cc) with 1.84" intake and 1.5 exhaust. These heads may have been found on the early 82-84 camaro with the 305HO motors.
The later 416 head had a larger chamber and commonly found with the 1.84/1.5 valves.
The 601 head can also be found on 82-84 chev trucks that came with the factory electronic spark control (ESC).
I would debate that the 416 head may outflow the 601 head due to the unshrouding of the intake valve. But the added compression of the 601 may offset that. Both points to consider.
Mark.
Mark.
Car: 4
Engine: 6
Transmission: 5
The 601 is not the HO head. It is the crap.
I have a 83 L69, the earliest kind of HO (there were no 82 "HO" motors); it came with 416 castings, 1.84"/1.5 valves. Personally I think that reports of other combinations are created by people who want to pose their 81 305 2-barrel van motor as a "HO".
Engine: TPI(s)
But back to the original question. If your in a racing class that requires the use of a stock unported head, then both the 601 and 416 offer unique advantages. But it depends if there is any restrictions on compression ratios and pistons.
I've run 601 heads on two 350's. Both times I had the heads machines to unshroud the valves. As the design was power band under 5000 rpm, these heads did well. A 416 offered quite a bit lower compression ratio, and the cost of new pistons was much more than machining the heads. In the end the 601 heads were the better choice.
I never ran either head on a flow bench as it did not seem like a good investment in cash. But visually looking at them, I can't say there was any signifigant advantage in either intake port. Both had the recess under the rocker stud, interferene from the casting for the valve cover bolt, and the bump behind the valve. The bowls were poorly cast. But I suspect the 416 would out flow the 601 purely due to the larger chamber and less interference. But will that flow off set 1 point of compression? All boils down to the package.
Mark.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
