L98 cam in all SD 90-92 305s check?
Old Jan 4, 2006 | 05:13 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
I have a '91 Formula with the LB9, N10 opt. dual cats, G80 rear and five speed. Most of the literature says G92 cars came with the L98 cam:
From Tech data on TGO website:
1990-1992
305 5spd / 305 AT 10088155* .350 .384 179 194 109.0
305 G92 5spd / 350 AT 10111773* .413 .428 202 207 114.5 (116/-116)
*roller cams
Should this be amended to say also G80 five speed? Everything I am reading here says I have the L98 cam. Thanks for your input!
Old Jan 5, 2006 | 11:42 PM
Car: 91 Formula WS6
C'mon you guys! This should be an easy one!
Old Jan 6, 2006 | 10:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
IIRC all TPI cars from 1990-1992 used the same Cam... LB9 or L98
It is an easy one
John
Old Jan 6, 2006 | 10:59 AM
Car: 91 Formula WS6
Thanks John! Now I can go on my merry way with the project...I'm having a good time with it!
Old Jan 10, 2006 | 02:15 AM
iroc22's Avatar
It is an easy one
John
Correct. There have been discrepencies in info over the years, but people have pulled L98 cams from their stock LB9's in the 90-92 years...regardless of options. (G92 or not)
Old Jan 10, 2006 | 08:26 AM
okfoz's Avatar
From 86-89 there WAS the "Peanut" cam in the LB9/A4's that was also used in the 86-87 LG4/88-92 LO3 engines.
The 87 L98 cam is almost identical to the 90-92 cam except the 90-92 cam had more lift. The 88-89 Cam was the most aggressive for the L98 engines, but with the MAF it was more restricted. The SD system is why the 90-92 was slightly hotter.
John
Old Jan 10, 2006 | 07:12 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Does that include the auto cars?
Old Jan 11, 2006 | 03:12 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Si.
Old Jan 11, 2006 | 10:39 PM
TA76's Avatar
A little off topic, but didn't the 85 TPI cars have a unique cam?
Old Jan 11, 2006 | 11:12 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
The way mine moves down the road it sure feels like it
Old Jan 12, 2006 | 02:16 AM
90TA's Avatar
'85 LB9 had the same cam as the L69. Same engines, just different induction.
Old Jan 12, 2006 | 09:52 AM
okfoz's Avatar
I believe that the L98 cam in 1987 is similar to the 1985 LB9 cam specs. The obvious difference is rather than roller lifters tho it was for standard hydrolic lifters.
John
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
