help with no vin #
Old Apr 16, 2009 | 05:34 PM
camarojuggalo's Avatar
Car: 1987 Iroc-z
Axle/Gears: 3.73 posi
help with no vin #
I got a camaro for 700.00 i know its a iroc its got the stock "wonderbar" and the door jam states 16 in rims but its a rebilt title and theres no vin int the window nor is the rpo sheet in the center nor is there in the hatch nor under the hood its got a il state police vin in the door but every thing else is gone how do i track down the org vin #
Old Apr 16, 2009 | 05:44 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: help with no vin #
find something on the panels. There should be a sticker on every panel, they probably scratched doors and hood, there is one on each bumper cover, as well as the original impact bars underneath the bumper covers (something they probably did not get to), along with stickers in each front fender, as well as the rear fenders i believe. Should be a sticker on the hatch as well. If i'm not mistaken, i thought the engine or transmission had the vin on it too, but maybe it's just the last 6, not sure.
If you haven't figured it out by now, when i say sticker, i mean there should be a long sticker with the vin number on it. Good luck finding it!
Jon
Old Apr 16, 2009 | 05:51 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The sticker issue began in 87 so he may have additional issues locating the VIN.
Old Apr 17, 2009 | 06:26 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the sequence number (last 6 digits) are stamped into the firewall on the engine side behind your heater box. Those 6 digits and the year could very well be enough to have the right person look up the rest of your VIN.
Old Apr 17, 2009 | 07:10 AM
Car: 1987 Iroc-z
so do i have to pull the heater box off (im doing that anyways) and it will be right there.......also i have some numbers on the firewall behind the dist but there scratched out in the middle
Old Apr 17, 2009 | 09:14 AM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
Ok that ILL STATE VIN PLATE in your door frame is your NEW vin plate because the one from the dash was damaged or stolen. At my job we deal with this all the time and have the state here once a month replaceing vin plates from stolen cars.
You will have to find the secondary vin (will have to ask the state where it is hidden)
I would expect if you can't find a vin anywhere but in your door plate your car was once was a stolen recovery. PM me if you have any more questions maybe can have the state guy take a look at it if your really needing the vin verified
Old Apr 17, 2009 | 10:27 AM
Car: 1987 Iroc-z
pm sent
Old Apr 17, 2009 | 10:56 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Yes, it's fairly large and you can't miss it when you remove the heater box.
Old Apr 23, 2009 | 09:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The VIN should also be on the Drivers side door sticker... the decal stating that it conforms to... at the bottom
I am not sure if this is the same as 1986 tho, this is from my 1987...
John
Attached Thumbnails help with no vin #-87-yellow-formula-de
Old Apr 24, 2009 | 10:16 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You could pull the carpet up many have build sheets under the carpet, mine had the vin on it, and a sticker on every panel.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Galaxie500XL
Feb 1, 2020 04:53 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
AussieZ28
Sep 30, 2015 03:36 PM
J.C. Denton
Sep 8, 2015 05:35 PM
