wiring harness and speakers
Old 02-25-2009, 10:06 AM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
hi guys....
Im looking for a wiring harness from the speakers to the the radio.
Also, looking for front speakers and rear speakers. let me know what ya got. thanks, brad
Old 02-25-2009, 11:00 AM
Suspended
cam91rs1's Avatar
Car: 91rs camaro conv
Engine: 305 tbi
Transmission: 700r4 w/shift kit
Re: wiring harness and speakers
ARE U LOOKING FOR STOCK SPEAKERS IF SO I HAVE THE 2 REAR AND 2 FRONTS
Old 02-25-2009, 11:36 AM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
yea that would be fine as long as they dont crackle and are in good shape. Have any pics? Price?
Old 02-25-2009, 02:24 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I have powerbase 4x6" laying around, never used them, don't need them.
Model ES 462X
4x6" Speaker Diameter
150 Watts Power Handling
4 Ohm Nominal Impedence
65Hz-22 KHz
90 Db Sensitivity
Composite Wool/ Kevlar Enhanced Paper Cone
High Damping Butyl Rubber Surround
High Powered Kapton Multi-Layer Copper Voice Coil
Customized Rubber Magnet Boot
Poly-Cotton Flat Progressive Spider
19mm Pivoting Balanced Pure Silk Soft Dome Tweeter
$30 shipped
Old 02-25-2009, 05:51 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
Model ES 462X
65Hz-22 KHz
90 Db Sensitivity
$30 shipped
Two of them? are they bolt in and go?
Old 02-25-2009, 07:31 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
yes they come with the hardware so the screws and some wire for both and a manual for them. No mounting hardware so if you wanted to raise it or something, but it has everything so it should just bolt right in and go, if not then you might need like rubber spacers to raise it a bit to fit, but those are like $1 at home depot for 8 which is perfect.
Old 02-26-2009, 08:33 AM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
Timinsk....Im already made a deal with a guy for a set of four. If it doesnt work out ill let you know. Thanks for your time.
Old 02-26-2009, 08:41 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
ok thats fine, if it doesnt just message me or post back on this thread about the situation. thanks
-Timinsk
crt454
Interior Parts Wanted
06-23-2017 02:25 PM
TheJoeY88
12-31-2016 07:30 PM
stalkier
12-06-2015 11:25 PM
Reddeath210
10-06-2015 08:20 AM
stalkier
08-21-2015 01:54 AM
Quick Reply: wiring harness and speakers
