[PA] Speedometer
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Speedometer
If your car is an 88 Camaro than you need an 86-89 camaro cluster. If you install an 82-85 cluster the wiring is not directly compatable and you will have cluster problems. And; you simply can't install a 90-92 cluster into an 88.
Need a 85 MPH cluster or a 145MPH cluster unit ?
What is your ZIP code ??
Elephantismo
Feb 13, 2019 12:51 AM
