How to mount a PS2
Old Mar 17, 2007 | 12:25 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
How to mount a PS2
Hey guys, I had a request to post something about mounting my PS2. Im not good with this kinda stuff like posting attachments and stuff so bare with me. Here's a brief explanation on how I did it. Feel free to ask me if you have any questions.
My apoligies for it not being actually mounted in the car. The Piggies didn't like it too much so I had to take it out (temporarly).
1. Go to Lowes and get just a flat peice of steel to bend up.
Bend it up so that it cradles the PS2 on the shelf on the front
3. I used two existing holes to mount my bracket under the dash; I think part of the HVAC.
4. Run your wires behind the center console. The RCAs running to the tv, and I just used a 100watt power inverter in the cig lighter to power the system. The only bad part was that if you were using it when the car is off and you start it, the power would turn off.
5. Some may have to support the rear of the system with another bracket. I did not have to support it because the power and A/V wires coming out of the rear supported it perfectly. They sat right ontop of where the carpet ends and against the firewall. It was enough to support the little stress that it was putting on the rear.
I think that about covers the basics. I'll post some pictures here in a few minutes. Let me know if you need any further help
Old Mar 17, 2007 | 01:52 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Heres what the overall bracket is gona look like...
Old Mar 17, 2007 | 01:53 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
the mounting hole on the right hand side
Old Mar 17, 2007 | 01:55 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
the mounting hold on the left hand side...
Old Mar 17, 2007 | 01:56 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
bracket mounted...
Old Mar 17, 2007 | 01:57 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Power inverter...
Old Mar 17, 2007 | 03:50 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Cool............now if I could just mount my espresso machine I would be all set.
Old Mar 17, 2007 | 08:37 PM
Pocket's Avatar
Car: 91 Trans Am
Not a big fan of the location, easily seen and stolen
I would move the inverter up under the dash too
Old Mar 20, 2007 | 12:31 PM
2wdr956's Avatar
Re: How to mount a PS2
Thanks a lot, man. This is exactly what I needed. I'm going to have to tweak a few things for mine, seeing as how my console is larger and heavier, but I think I can pull it off.
Old Mar 20, 2007 | 04:09 PM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
no problem buddy. Don't hesitate if you have any more questions
Old Mar 20, 2007 | 10:20 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Whats the matter? Your mom won't let you play the PS2 at home?
Old Mar 21, 2007 | 10:11 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Looks pretty cool. Why not go with the smaller PS2, I know are cars are not known for space?
Old Mar 21, 2007 | 10:22 PM
85camarodude's Avatar
not trying to be mean but it looks tacky, you just screwed it to the bottom of your dash, your converter is an eye sore sticking out of the cig lighter, and to top it all off you're using the big ps2 which is ugly all by itself. maybe if you could like cut a cubby in the dash for the ps2 to sit in with a cover to go over the front when not in use. i always thought itd be cool to have it sit above the radio and hvac controls but not just hanging under my dash.
Old Mar 22, 2007 | 08:59 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Or maybe you could also put in an Xbox 360 underneath the ps2, and then a Nintendo Wii box under the seat with a 46" plasma in the hatch area and using a wireless internet connection you could eat Cheetos while you play Halo online and wonder while your ***** is orange.
That aint right, Lord I apologize for that right there and be with the starving pygmies down there in New Guinea there, Amen.
Old Mar 22, 2007 | 09:53 PM
HCR13's Avatar
Car: 1987 Trans Am
WTF? ^
Old Mar 22, 2007 | 10:12 PM
RookieCamaro's Avatar
Car: 1992 Camaro RS
Transmission: 700-R4
Originally Posted by HCR13
WTF? ^
My thoughts exactly, lol
Overall though, it does look somewhat tacky, and the previous suggestions are good. I would hide that power converter though stat.
Old Mar 29, 2007 | 12:50 AM
Kandied91z's Avatar
quoting the king of *******s that's funny considering you've been registered since 04 and you wait to post crap like this it's no wonder your not around much lol... nice work ace, it made me laugh!
chevyguy5 adding the ps2 is a nice idea, especially for show cars as it can get boring or if your looking to have something to do on long drives however i can't nicely comment on the overall look of your install so we'll just leave it alone. to some of the other comments the larger ps2 is a major heat sink... enclosing it will cause problems so while the area he chose doesn't look good it's really ideal for the unit itself. i personally would have hidden it though and any wires now days coming from your cigarett lighter is a no-no. i do compliment you on it at least working though!
i just put a ps3 in my 91 more or less just because, i had a ps2 in the car and i must say the ps3 is much nicer. with the wifi i can access the internet now while i'm sitting around at a show as well as the other goodies and it's wireless controllers help for turing it off.
i would suggest moving the unit to the rear of the car. hard wire your inverter so that you don't have wires running everywhere and go spend $20 on wireless controllers. it will look a lot better and in the end isn't that the point as i can't imagine you put a ps2 in your car just because you like to play games..
Old Mar 29, 2007 | 01:13 AM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
Hey LOOK! i play ps2 while runing over little kids playing in the road!
Just Plain wrong in a thirdgen. your the kinda people that make some thirdgens look like white trash. instead of the damn good looking cars performance minded cars they are. want that kinda stuff in the car you drive Buy an SUV atleast then theres alittle more room for all that stuff
Just my
Old Mar 29, 2007 | 02:14 AM
Kandied91z's Avatar
Re: Hey LOOK! i play ps2 while runing over little kids playing in the road!
Just my
so because this person tries to put a ps2 in his car he's considered white trash? at least he's interested in something and trying. you might not agree with it but 90% of the white trash population can't afford a cd player let alone a ps2, who cares if this person wants it this way.
on that logic i guess my car with a 700 horse blown ls6 is white trash because it has a ps3? well so be it lol... at least i look damn good sportin my mu!!et and while i'm waiting for you to finish our race i can check my pm's on thirdgen.org at the nearest starbucks.
it's great to be white trash..
Old Mar 29, 2007 | 02:22 AM
ooooooooo, burn!
Old Mar 29, 2007 | 04:08 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Git'er dun!
With that said.
If you think about it, and are on a small budget the console you would most benefit from is the xbox. (Not 360, although it would work the same way). You have a hard drive that you can just load up with MP3's, you can even save your games to the hard drive so that your CD doesn't f-up every time you hit a bump. That all together would probably cost you around 80 bucks.
Now, if you want to be cool, and install something worth your while, visit www.mp3car.com check out their FORUMS.
I guarantee you will spend days there researching and looking at sooo many different possibilities.
Last edited by xlwhellraiser; Mar 29, 2007 at 04:13 PM. Reason: Automerged Doublepost
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
