Headlight knob removal
Old May 10, 2007 | 08:44 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
Headlight **** removal
I have a 92 Camaro, my bulb on my instrument panel is out. I am trying to find out how to take the **** off. Any other info with tearing the panel off would help. Thanks
Krista
Old May 10, 2007 | 09:44 PM
CommieTerrorist's Avatar
Car: 92 Camaro RS
Engine: lO3
Re: Headlight **** removal
There is a small button on the underside off the switch inside the dash. ( where the ***** shaft goes into.) push the button in and pull the **** out. Also disconnect your battery as this will turn your headlights on.
A Chiltons or haynes manual may be a good investment if you plan on doing a lot of your own work. They have a lot of stuff like this in them. ( thats how I knew how to take the **** off)
Old May 10, 2007 | 10:18 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
I have a haynes manual, but it has instructions for the early third gens . Guess will have to look at a chiltons. The early third gens has the **** to the on another little cluster thing, but oh well. Thanks I will try this.
Old May 10, 2007 | 10:56 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
I have a Chilton's. Neither book is super detailed about the procedure. It just tells you to press the button on the switch. It was a pain in the neck to get to IMO.
Old May 10, 2007 | 11:00 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
mines just pull of if i pull with a little bit of effort...
Old May 10, 2007 | 11:26 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
Another question, can I buy orange bulb in the 194ll style? Ok maybe I should say I am wanting to change the color to a brighter orange, my b/f put red light on his 4th gen panel. Think that orange will be hard to find or is even possible?
Old May 11, 2007 | 10:57 AM
Car: 92 Camaro RS
Engine: lO3
Well, you could get the LED replacement bulbs from here:
http://www.superbrightleds.com/1157.htm
They are actually reasonably priced and do come in different colors. I wish I had order from them, but I decided to make my own LED bubls which are OK but not great.
Old May 11, 2007 | 10:57 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
Thanks for the help, but I can't find that small button. Is it behind the ball or on the back side of the trim? I tried turning it, but I afraid of braking it. That bulb is going to have to be replaced soon, I can't see how fast I am going!
Old May 11, 2007 | 11:14 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
The LED's do I need to change wiring on doing that? What size would I need a big instrument cluster bulb or the smaller one? This is the page with the two one it... http://www.superbrightleds.com/cgi-b...5.9306&next=50
Sorry for being a pain, but lights aint my thing
Old May 12, 2007 | 11:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
There are 2 ways of getting to the button:
1-Remove the dash pad, stick your hand down the hole and feel for it, it is located behind the headlight dimmer switch on the bottom.
2-Remove the speedo, same deal.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
