plastic panel under the driver side dash......?
Old Jun 17, 2007 | 04:27 PM
86irocterror's Avatar
i have an 86 iroc 5 speed. my car did not have the plastic panel that goes underneath the dash in between the pedals and the bottom of the dash. i have never seen one in a 5 speed car, only in autos. does anyone know if they had one for the 5 speed or not. i got one for an auto at the junk yard yesterday for 3 bucks and its for an auto. im just going to notch it out for the clutch pedal. just trying to find out if it was an auto only piece or not. thanks guys!
Old Jun 17, 2007 | 04:48 PM
j dezzy's Avatar
Car: 87 TA
Re: plastic panel under the driver side dash......?
yeah they made them for manuals. I've also been told that if you look at the back of an auto hush pannel that there is a line that shows where you should cut it to compensate for a clutch pedal. I've never checked myself. but that's what I've been told.
Old Jun 18, 2007 | 05:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC (T-5) has the panel.
JamesC
Old Jun 18, 2007 | 11:03 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
wow yeah hes right at least my 82 one has a line cut out spot for the clutch pedal even though its an auto car
i dunno about 85-up but im sure its the same way
should be an obvious line cut out on the panel for the clutch pedal arm
i dont see any good reason that a car would not get an under dash hush panel just because its a 5 speed
good luck
Old Jun 18, 2007 | 01:19 PM
j dezzy's Avatar
Car: 87 TA
checked my 87 auto TA, it's got the lines to cut out for a manual. just another way they tried to make these cars completely universal for their generation. only make one hush pannel, just cut along the line to make it a manual. lol.
also, my 84 is a 5 speed and it has a hush pannel.
Old Jun 18, 2007 | 02:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
neat
thats what i figured
its good to learn more about these
and just for fun heres my 82 trans am auto trans hush panel
theres a part number on the piece that you cut off the panel for the clutch pedal arm clearance, it is one sequential number lower than the part number on the panel itself
Old Jun 18, 2007 | 02:34 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
the way i understand it many IROCs were optioned without this under dash plastic. i have never seen any other Camaro or firebird without it, only IROC camaro's. and i have only seen one of those (you can tell because they have metal brackets that hold the courtesy lights)
Old Jun 18, 2007 | 03:03 PM
JamesC's Avatar
This topic was, IIRC, thorougly covered in the following link (there doesn't seem to be a rhyme or reason for which cars received the panels):
https://www.thirdgen.org/forums/hist...ght=hush+panel
JamesC
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
