4th gen Camaro Firebird console differences??
Old Jan 10, 2008 | 11:17 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Does anyone know if there are any significant differences in the Camaro and Firebird/TA 6 speed center consoles. I'm lookin' to put one in my 91 Firebird and wanna know if they 4th gen Camaro consoles are the same and will fit fairly easy like the Firebird/TA ones are supposed to. Anyone have any input on this?
Tom
Old Jan 10, 2008 | 11:49 AM
Faded's Avatar
Car: '91 Firebird
Re: 4th gen Camaro Firebird console differences??
The 93-96(97?) Camaro consoles will not fit in the thirdgen (unless you have a matching 4th gen dash).
All year bird and 98+ camaro consoles will fit.
Old Jan 10, 2008 | 02:12 PM
MNformula350's Avatar
There are 3 main styles:
93-96 Camaro (which as has been stated is not a direct swap, requires custom fabbing to look/fit right)
93-96 Firebird (my personal choice, cleaner look, what I put in my Formula)
97-02 Camaro/Firebird (Same center console Available in either Black or Gray)
Only real current pic of my Formula's interior with the console:
Old Jan 10, 2008 | 04:19 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Very cool, just the type of info I was looking for. Thanks guys.
Tom
Old Jun 13, 2008 | 04:40 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
so you didnt have any problems with the radio and hvac controls? does the bottom of the console itself sit lower? i cut my carpet too short so i dont want it to show more...
Old Jun 15, 2008 | 04:07 PM
Celticsfan's Avatar
Car: 1985 Trans Am
bumppp
Old Dec 28, 2008 | 04:22 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
lt1 center consoles from camaros arnt direct swaps? What exactly needs to be fab'ed to make em work. I got a guy coming right now to trade my 4th gen wheels to for a lt1 center and a 4th gen rear. I may have just traded for a white elephant
Old Dec 28, 2008 | 04:46 PM
Stephen's Avatar
Car: 87 GTA
I love these resurrected threads!
What's the difference between those two?
Old Dec 30, 2008 | 11:12 PM
jersyboyy's Avatar
Car: 85 Camaro
anybody? what needs to be fabbed up for a lt1 camaro center console
Old Jan 11, 2009 | 09:24 PM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
just a quick question on fitting, I have a 85 z28, the radio pod and console is one piece, will the radio pod from a third gen TA bolt in along with the forth gen center console?
I have been thinking about doing the swap and finding that most of these conversions are with TA's and firebirds.
Old Feb 26, 2009 | 11:39 PM
popballz's Avatar
Car: 89 firebird
quick question, is the 5 speed and 6 speed center console boot the same? anyone know?
so i found this
Originally Posted by FLYNLOW92rs
Get a console from a 97+ car......You WILL need a manual plate......
The 5 and 6 six consoles are the same, either will work, the ONLY difference is the shift pattern........
Comes with 4 cupholders and 2 extra cigarette lighters......A place to mount switches.....
Here is a pic of mine installed with some cutting to make the 3rd Gen radio pod to work
Any more questions just ask.......
so i am guessing they are the same?
Last edited by popballz; Feb 26, 2009 at 11:41 PM. Reason: i think i solved my own problem!
Old Feb 27, 2009 | 12:04 AM
deoverton's Avatar
Car: 1992 Camaro RS
also is there any differense from the auto and manuel consoles to wether or not you have an auto or manuel. I have a stock 700r4 now but in the future will have a t56 but would hate to have to have 2 differnt consloles
Old Mar 15, 2009 | 09:34 PM
Jairo's Avatar
i have a 94 camaro console in my ta. fits perfect but there is a gap between the radio and the console itself. (i was thinking of putting gauges or something there, idk yet) yes, 4th gen consoles will fit on a third gen but make sure its eather a firebird/transam/formula console. like i said before, the camaro one will fit but will leave a gap.
make sure you get a manuel shifter boot too. ill show a pic of mine when i have a chance.
Old Mar 15, 2009 | 09:35 PM
Jairo's Avatar
im with him. what EXACTLY do you need to do to make it work?
Old May 16, 2009 | 12:22 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
apparently I need to read more often. I goofed and got a 93-96 Camaro auto console from the junk yard today (since that was all I could find for 4th get cars. I kinda figured I'd be in for some work using an auto setup instead of the manual, but I'm up for a challenge. We'll see what happens....
Old May 16, 2009 | 12:37 PM
Stephen's Avatar
Car: 87 GTA
Manual consoles will work good in an Auto car.
My 87 (700R4) GTA came stock with a manual style boot with a slider indicator along the side.
At a glance, it looks like a Manual car.
Old May 17, 2009 | 07:45 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
So a quickly update here. Played around with the console yesterday. As previously stated (here and elsewhere), the early Camaro auto console is not drop in and go. You should be able to see from the next couple pics why.
(don't mind the mold; the car was horribly covered in it when I got it a couple weeks back, still trying to clean it all out).
There is a very large gap between the radio and the console. What you cannot see is the fun I had trying to fit the shift plate. Is it worth the struggle and aggrevation to make this setup look good? Your call, your time, your money. I may have a lead on a manual Firebird console for cheap, we'll see what happens.
Old May 18, 2009 | 10:13 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Resurrection.. is good. I am looking to do this project as I have once Jacked up a perfectly good 4th gen firebird 6 speed console trying to do this last time with a B&M megashifter. pics up!!
Old May 21, 2009 | 08:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If all goes well, I should have an LT1 firebird console arriving before the weekend. Definitely will have some pics asap.
Old May 21, 2009 | 11:24 PM
3rdGenIrocZ's Avatar
another 4th gen console question. . . .
i used a 2002 fiirebird console. (pics of how to do the swap)
It is great. way better then old box **** console. dont miss it at all
easy swap with a manual. if you have common sence how to use an automatic without looking to know where u are its easy.
who ever says the console wont fit without a dash is wrong. just need a firebird pod.
looks like a manual
only negative thing is that every1s in awhile the radio pods trim will pop lose on one side. (not a big deal)
Old May 29, 2009 | 09:06 PM
85camarojunkie's Avatar
Car: Camaro coupe
I am in need of a console myself and am curious how much of a hassle it would be to use an automatic console in my 85. I have a megashifter and i know i can disasimble it to get the console around but anyone using the auto ones?
Old May 29, 2009 | 09:20 PM
Stephen's Avatar
Car: 87 GTA
Just use a T56 console for your 700R4.
My 87 GTA STOCK console, came with a manual style leather boot, on the 700R4 handle. Looks like a manual from the outside.
Old May 29, 2009 | 11:27 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
those consoles sit too high
Old May 29, 2009 | 11:30 PM
Stephen's Avatar
Car: 87 GTA
How so? Your the first person I've ever heard say anything like that.
Old May 30, 2009 | 08:18 AM
92 Camaro's Avatar
they do. the console compartment and lid sits higher than a 3rd gen's.
Old May 30, 2009 | 08:06 PM
what are you talking about lol. the shift area of a 4th gen console is basicaly the same height as my seats. the console sits low. If your talking about the storage area i think they are just about right. feel freaking comfortable. if you dont beleve me look at my sig link and youll see exactly how it sits.
Old May 30, 2009 | 09:25 PM
92 Camaro's Avatar
no, I said the console compartment with the lid.
Old May 30, 2009 | 09:28 PM
Stephen's Avatar
Car: 87 GTA
By how much? 1/8"? 3"? <--sarcastic
I've never noticed the difference...
Old May 30, 2009 | 09:34 PM
92 Camaro's Avatar
lol
Old May 30, 2009 | 10:21 PM
maybe the console hes talking about been sitting in the sun to long? all in all. upgrading to a 4th Gen console is great.
Old May 30, 2009 | 10:23 PM
92 Camaro's Avatar
those consoles have been sitting in the sun too long? they don't look bad to me.
Stephen's Avatar
Car: 87 GTA
lol
And that means.....WHAT?
Don't care to explain just what you mean by "too high"?
Old May 30, 2009 | 10:27 PM
no i was saying that maybe the console he seen that sits to high has been in the sun to long and maybe expanded. was joking. but i didnt even notice that they are to "high"
92 Camaro's Avatar
WHAT
the one Dan posted looks almost 2 inches higher from the seatbelt.
I wonder how he's going to make that console work anyway.
Old May 30, 2009 | 10:32 PM
oh my bad, didnt mean you were talking about dan. i thought u were just stating your experience. im sorry for the confusion
And he could trim it if its to high
Old Jun 1, 2009 | 05:57 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
WHAT
the back end of the console does seem to sit higher than the original one, but since the front end sits a lot lower than the original, it skews the perspective a bit. The arm rest is a very comfortable height as-is, and I'm only 5'8".
I have given up on making this one fit; as mentioned before, I ordered up a manual console to get things done with less work. To get the shifter to work right and line up with the console cover, there is a lot of trimming/adjusting/massaging needing to be done. Not a challenge I feel like spending the time on currently with so many other things in need of doing (like a motor swap).
Old Jun 3, 2009 | 06:16 PM
Car: Camaro coupe
3rdgenIroc, did you use a shifter cover i looked at your cardomain but couldnt see. Im interested in trying this out with an automatic one and trying to lower my megashifter to get it to fit in there.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
