key wont turn!!! need help :(
Old Oct 16, 2008 | 05:06 PM
popballz's Avatar
Car: 89 firebird
so i go to start my 89 firebird today, and the key turns like normal, then just stops.... i try to turn it back and it wont go back, i keep moving it around (forcefully) and it does nothing.... and i can take the key out when i shouldnt be able to.... and the key doesn't go all the way back to off position
so i guess something is broken inside the steering column? anyone know what it would be?
here is a little video of the problem....
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/3F35dHHTJeo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/3F35dHHTJeo&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
look here if that doesn't work.
http://www.youtube.com/watch?v=3F35dHHTJeo
if you need to know anything else just ask.
Old Oct 16, 2008 | 05:37 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: key wont turn!!! need help :(
i had the same problem i took the column apart and there was a peice of plastic jammed into the gear at the end of the ignition cylinder took me almost 3 hours to find and fix it
Old Oct 16, 2008 | 06:10 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My 92 gets stuck sometimes in the foward position (won't turn off). I use some WD 40 sprayed in the lock cylinder and everything works fine for like 6-8 months.
Old Oct 16, 2008 | 06:54 PM
popballz's Avatar
Car: 89 firebird
is there any way to take the clip out without the special tool?
Old Oct 19, 2008 | 07:59 AM
trans_x1985's Avatar
Car: 1985 pontiac transam WS6
Transmission: t-5 5 speed manual
is it an automatic or standard?...i know on standard, you have to push down on a switch just behind the key switch
Old Oct 19, 2008 | 11:19 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Call a locksmith and have him replace the lock cylinder & keys . Sounds like it is wore out, samething happened to me. Cost me $75 for locksmith and no headachs.
Old Oct 19, 2008 | 11:21 AM
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
Thanks for the heads up.I'll spray lube the lock cylinder; I did all the outside locks but forgot this one.I hope your problem is a easy fix.
Old Oct 19, 2008 | 12:34 PM
popballz's Avatar
Car: 89 firebird
well it was the lock, and its all better now.... it sucked not being able to drive
Glowsock
Jul 24, 2025 03:15 PM
Glowsock
Aug 31, 2015 09:01 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
