which steering columns are compatible with a 89 camaro
Old Dec 30, 2008 | 12:34 AM
ILUVMY89's Avatar
i need help i need to know wat kind of cars i can pull a steering column out of that will work in my 89 camaro its my daily i did a search and nothing came up in reference of what years and vehicles one could be pulled out of thanks in advance
Old Dec 30, 2008 | 04:06 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: which steering columns are compatible with a 89 camaro
I have one from a '91 RS. That might work for you, if you're anywhere near the Olympic Peninsula.
Old Dec 30, 2008 | 06:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
most should interchange , there is a difference between man. trans. & auto trans. columns . you may have to swap some brackets . stay away from airbags if you can . i swapped an 89 into an 88 and had to swap auto trans cable stuff over . remember cruise & wiper sw. , make sure they are the same . not a bad job , but a PITA . good luck .
Old Dec 30, 2008 | 11:00 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Well, it depends if you want the exact column or just one that will work. 1989 was a one year only column because it was the first years for VATS but the last year with no airbag. So if you want to keep everything working the way it should you need a column from an '89. However, the '84-'88 columns are identical to the 1989 column except they don't have the chip in the key. You can put in an '84-'88 column but you will have to disable your VATS system or the car won't start. Also, if you find a column from an '89 you need to get the VATS module along with it because it needs to match the chip in the key. On an '89 it will be in the dash to the right of the column and just above and to the left of the radio. It's not easy to get to!!! It will be a black or gray box that will say Passkey on it.
Old Dec 30, 2008 | 11:21 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
If you go with something <89 let me know. I can help you out with disabling the VATS.
Old Dec 31, 2008 | 02:03 AM
ILUVMY89's Avatar
everybody thank ima see wat i can find locally and see what i end up with ill let everyone know though i had one yesterday but when i showed up at the junkyard some one had already messed it up
Old Jan 4, 2009 | 02:27 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
I have one from an 89 IROC which is in really good condition. I also have the vats box and coded key...
Fivestar
Old Jan 6, 2009 | 10:29 PM
ILUVMY89's Avatar
i got one off ebay thanks everbody im sure ill have more questions later thanks
Old Oct 13, 2017 | 02:12 AM
Dom Johnson's Avatar
I've got a 92 and an 89. Both V6. The 92 has a <89 steering column in it. I want to swap it to my 89. Can you help me on the VATS disable?
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
