headliner repair w/fiberglass ??
watching an episode of Overhaulin they were making a custom sub box.watching this box get built made me wonder can't something just like this be done with the headliner???my headliner isn't trashed so it would be a good base.I have of course never tried anything like this or I wouldn't be posting this to see if anyone else has tried something like this. if anyone has any pics of a headliner that has been redone using fiberglass or something similar to strengthen the headliner please be all meens post the pics.
Re: headliner repair w/fiberglass ??
Mathius
1 Post
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
i fiberglassed over my stock piece. it does add a little size and weight but nothing the original mounting couldnt handle. i also basically removed the sunvisor holes and made it smooth there. the floppy visors were more of a pain then anything.
the stock piece is really fragile, so go slowly. i may have even broke mine a little but stuck it back togethor when fglassed.
recovering is not easy, either, due to the corners at least on the t-top. so i used a piece of black braided type fabric to line the corners on top and it looks pretty good.
has held up very good for 5+ years now.
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i did mine with resin also, and repaired the tears with fiberglass.sand the edges and the side to be glued with the headliner, get all the bumps out. it will work fine. plan on atleast a gallon of resin. DO SMALL SECTIONS AT ONE TIME.
1 Post
Car: 89 firebird
and so your guys just used the resin? would think work to re-shape it where it is no longer the correct shape?
Car: 1991 RS Camaro
Engine: 350 0.060" over
A gallon? Just yesterday I laid up three layers of ~14oz fiberglass on a 8 foot by 4 foot mold. It was way oversaturated to the point of pooling, and I didn't use a full gallon of resin.
Engine: 305 tpi
Transmission: t-5
well i wanted it to completely soak in and on both sides, this way it was solid. the compressed fiberglass headliner soaked it up really thirsty
1 Post
Car: 86 TA
i used the fiberglass cloth as well as the resin. added strength and helped hold things together.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
I fibreglassed mine around the edges w/ cloth to stop it from fraying, then i re-wrapped it in suede
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
if your going to fiberglass it, could you just smooth out the imperfection with a minimal filler and paint it instead of recovering in cloth or what ever?
like you can with say a sub enclosure.
Car: 1991 RS Camaro
Smooth enough to hide under fabric and smooth enough to paint are two very different things. Also, I personally would prefer to have fabric there rather than a hard surface. That last part is purely opinion mind you.
But IIRC, the f-body has no interior trim piece across the front of the headliner, so on a non t-top car, there's a huge chunk with nothing holding it up but the visors. I don't recall much in the way on the sides either. I think the coat hooks hold it up on the sides.
If it were me, and I were gonna glass the headliner, I think the cleanest way to ensure it stayed up and hide the hangers would be to install an overhead console.
Mathius
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Check out the link in my signature on page 6. I Fiberglassed mine and recovered it. Came out great
1 Post
Car: 86 TA
found some pics.
this first one is what your corner may look like. the fabric was not stretchy enough for me to figure any other way around this. maybe the steam heat it or something at the factory who knows.
1 Post
Car: 86 TA
this is with the fabric strip glued on with stron fabric glue. you can see it hides the corners quite well.
1 Post
Car: 86 TA
finally i put a black liner on the inside so even if you see in there it will look nice.
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
auto, bac, backer, california, car, county, custom, fiberglass, fiberglassing, fibreglass, fix, headliner, hole, orange, repair, replacement, resin, strengthen
