Very annoying feature!
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
Okay, this could be cool to some people, but I find it annoying. I have the rear view mirror with the dual reading lamps, and there is a little light on the bottom, right side of the mirror that always comes on when the running lights or headlights are turned on? Is this a map light? What is it? It is really distracting.
Re: Very annoying feature!
Car: 1990
Axle/Gears: stock
you have a short in the circuit, probably in the wiring by the light - FIX IT - or it will decide to go on when you dont exopect it and stay on and drain your battery.
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
AHH..just pull the friggin' plug!...keeps the battery from gettin' drained!
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I love that little light. Mine isn't very bright though. I lights up the shifter/center console area perfectly. I don't really know what it's for or why GM put it in there.
It only comes on when my headlight **** is pulled back for the running lights or headlights. Sucks for my battery, I drive around all day (when it's dark enough/overcast) with my running lights on... I love how eye-catching the bright orange running lights are on F-bodies! Catches people's eyes from a mile away!
Car: 86' Z28
Axle/Gears: 2.73 (for now)
lol You know whats bright as crap in my camaro, my turn signals at night, are they supposed to have a green like lenses or somethin cause mine arn't and they are pretty bright.
It is kinda neat though. It lights up the stuff hanging on the rear view mirror! Lol, I should hang some girls panties from my mirror so every time I drive by someone or pass them all they see is these brightly lit up panties, and they'd be like "WOAHH!!!" Lol... can you people tell I'm a teenage guy or what?
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
So the switch to turn that particular light off doesn't work???
Weird. Sounds like wiring issue or the switch broke.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
be glad your mirror is in good cond. just dim the int. lights by turning the headlights ****.
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have that little little light but I have a manual and mine is dim so its bright enough to show gears but no enough to be annoying.
Car: 1992 Camaro RS
I love that little light. It has made it easier to do things at night instead of having to turn the dome light on. I just wish it had a little whiter color instead of the yellow color I have.
I'll dim it.
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
My 92 z has the same thing. It is not mentioned in the owners manual that I can find, but I believe it is just a courtesy feature. I think it is just a part of the DC4 option. Mine isn't bright at all, and in fact is a nice little feature to have. Could your mirror possibly have a brighter bulb that required in it?
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
That little light in the middle of the mirror is to light up your power window and mirror switch on the center console as well as manual gear shifter. The 4th gen cars have a similar feature in the form of a small red LeD above the controls on each door to illuminate the window switches.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My 1992 RS has it as well. I have a teal green car (just had HOK Candy Teal sprayed on), and I made green courtesy lights in the floorboards with green LED's. When I found that little light in the mirror, I cut a small piece out of a Mountain Dew plastic bottle and inserted it in the mirror - so now it's just a slight green hue that barely lights the center console area.
Elephantismo
Feb 13, 2019 12:51 AM
