92 RS dash emblem removal?
Old May 12, 2009 | 09:30 AM
menglish's Avatar
I want to install my new RS/25 th anniversary emblem on my dash and need to know how to do this? Thanks for any help...............
Old May 12, 2009 | 12:34 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: 92 RS dash emblem removal?
Ok, go to your local auto store and get epoxy, make sure to get one with the pluggers that will help mix it correctly, so it will make a good mixture and look on the back or side to make sure it will bond plastic and metal. (If you really have no idea, ask the guys working there, they should know and will help you.) I recomend getting the 60 sec as it will harden fast so you will not need to sit there forever and it's strong enought to do the job and not over kill if you need to pop it off again. Go home read the instruction on the back and follow.
Old May 12, 2009 | 12:59 PM
menglish's Avatar
Thanks....one more question. How do I get the old one off? Do I just pop it off with a knife or do I have do go into the dash?
Old May 12, 2009 | 01:12 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
I found that pulling baby oil around the edge of the emblem and leting it sit and then taking a hairdryer and heating the emblem up, makes it come off the best.
Old May 12, 2009 | 02:06 PM
menglish's Avatar
Thanks for the help...........this website rocks and I graduated high school in 1986 and these (3rd gen) are my dream camaros.........didn't make any IROCs in 1st, 2nd or Fourth and I think these camaros are sleepers on the investment market and their day is comming soon.
Old May 12, 2009 | 02:40 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Aren't there tabs on the back that insert into two holes pre-drilled in the dash?
Old May 12, 2009 | 06:50 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
The emblems just snap into the holes in the dash. The old one just snaps out. No thread nuts, nothing.
Epoxy?!
lulz
Old May 13, 2009 | 03:18 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
No need for epoxy. Just slide something flat like a screwdriver or butter knife and pop it foward. Re-install with double sided emblem 3M tape. Entire process 3-5 minutes.
Old May 13, 2009 | 04:16 PM
Kevin84Z28's Avatar
Has anybody thats posted come across a DASH emblem that was put on from the factory with any kind of adhesive? I've pulled dozens of these things off and every one had tabs...No adhesive, epoxy, 3M tape etc... You would need something like that if your tabs were broken, but if not they just stick in the pre drilled holes.
Vintageracer
Jan 10, 2020 05:33 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
