Key stuck in the ignition
Old Sep 13, 2010 | 12:49 PM
cmbtmdc's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
the key to my 89 formula is stuck in the ignition, any ideas how i can get it out?
Old Sep 13, 2010 | 12:58 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Key stuck in the ignition
At least you dont have to looking for it! Hate when that happens..
Can the car be started? If so, you might drive it to a lock smith service. If not, some smith's make house calls. Beats having to pull the cylinder or buggering it up trying to fish it out with a probe and needle nose. Although, a surgeon's hemostat clamp (sold at most sporting goods stores) will work if you can get the nose onto part of the key shank.
Good luck
Old Sep 13, 2010 | 01:06 PM
cmbtmdc's Avatar
Engine: 305 TBI
lol yeah it starts im just more worried about it getting stolen if i go somewhere...i got a set of hemostats (army medic, didnt pay anything :-P)
Old Sep 13, 2010 | 01:21 PM
Wadebryant's Avatar
Guess I know who to call when my car gets sick!
Good luck
Old Sep 13, 2010 | 01:28 PM
cmbtmdc's Avatar
Engine: 305 TBI
haha, i only know basic mechanic stuff...working on ppl is another story
Old Sep 13, 2010 | 11:16 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello cmbtmdc!!
Spray a little bit of "lubrication" into it before trying to get it out!!
WD-40, lock de-icer, graphite lock lube should work, not lots, but just a little!!
This should help to remove it, and prevent it from happening again, in the near future!!!
Make sure to move/wiggle the key around, and switching the lock cylinder from position to position!!
Old Sep 14, 2010 | 11:19 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
not too be ignorant, but is it in park when u try to take it out? i know mine i had the same problem and i had to push the shifter as far forward as i could before i could take it out..
Old Sep 14, 2010 | 11:51 AM
cmbtmdc's Avatar
Engine: 305 TBI
after i read this i went outside to look at the car...yes its in park, but i can move the lever without pushing the button...its like the car doesnt recognize that its in park....anyone got any ideas?
Old Sep 14, 2010 | 01:09 PM
vinny83's Avatar
hmm, if u take off the cover for the shifter and look underneath, is there two cables attached to it? one controls the transmission, and one goes up to the ignition (lets u take out the key) the one cable might be messed up. i believe its the cable on the right.
Old Sep 14, 2010 | 01:27 PM
cmbtmdc's Avatar
Engine: 305 TBI
ill take a look at it, thanks
Old Oct 16, 2010 | 07:47 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I have the same problem, there is something broken in the steering column. In order to get mine out i played with it and got it out. When you didnt have the key problem and the car was off, could you still move the shifter? With mine i will have the keys in the house and i can push the shifter right into reverse and then back to park.
Old Oct 16, 2010 | 02:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The cable can be adjusted from the trans end.There is a 10mm nut loosen that.The hole is slotted so the cable can be adjusted in the proper place.Service manual says to put the trans in nuetral first.The loosen the nut, the cable should automatically move to the right spot.Then tighten back the nut.
If you dont hear a click when you put the trans back in park.More than likely the cable is out of adjustment...usually.If not, .
Old Oct 16, 2010 | 06:28 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
What if you can only move the shifter into reverse but nothing else, do you think its still a loose cable?
Old Oct 16, 2010 | 08:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The shifter is probably not locking in Park, thus allowing you to go back into Reverse.It could be a number of other things i cant think of.That click though means the shifter locked in park.
Old Oct 16, 2010 | 08:47 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
but maybe try to push the car a little in park & see if it moves or "clicks".
Good luck!!
Old Oct 17, 2010 | 12:28 AM
CamaroIROC88350's Avatar
Look underneath your car and check to see if the transmission cable is hooked into place like it should be. If it isn't, bolt it back in (2 bolts) and see if you can put it into Park.
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
TexasMaro
Sep 15, 2015 06:50 PM
383cam
Sep 9, 2015 06:01 AM
