'91 Camaro Z/28 Leg Room
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: '91 Camaro Z/28 Leg Room
My brother is about that tall and sits comfortable in his '92. I can tell you that there is much more available headroom with standard manual seat tracks. The power tracks are higher, even when adjusted all of the way down.
Im 6'2 and my heads pretty close to the roof, but I think a 6'4 guy should still have no problem. Cars an 85 firebird manual seats, but I assume its the same as a camaro's.
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Are you sure? Because in my car the power seat is all the way to the floor and it is alot lower than when I sit on the passenger side. I can feel the difference.
Engine: that I like
They did change the design of the power tracks around '85. The early ones seem to go just about as low as the manual tracks.
That explains it because mine is an 87 and the only time I sit there is when Im working on something in the car.
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Hi, I'm 6'5" and can sit comfortly in both seat types, but there seams to be more room in the hardtop car's. I now have aftermarket seats for which I made brackets, and now I can even sit straight up with a helmet on.
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
im 6'4'' and i have no problem sitting in my 92 z28 either of them. (one power other is not). other then i have a raw spot on my knee from the center consol rubbing it to the bone lol. not that bad (yet)
