4th gen console in 3rd gen camaro with stock dash, any pics?
Old Jan 29, 2011 | 06:05 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I remember seeing someone that did the 4th gen console in a stock 3rd gen camaro with the stock dash. Does anyone have pics of that swap? I was looking into making some change inside the car because its to plain, and it would be nice to have a cup holder with out modding one in the 3rd gen console. If anyone has pics of it done please post them i want to see how it would look. Thanks
Old Jan 29, 2011 | 06:07 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th gen console in 3rd gen camaro with stock dash, any pics?
Old Jan 29, 2011 | 06:21 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Is that in a camaro?
Old Jan 29, 2011 | 06:23 PM
Stephen's Avatar
Car: 87 GTA
Because of the way the Camaro radio & AC controls are mounted, the only way to do it in a Camaro is to swap in a Firebird radio & AC pod, along with the 4th gen concole.
Old Jan 29, 2011 | 06:27 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Yea that was going to be my question. I guess it wouldnt hurt since i already have the GTA A/C control unit. Now the firebird/GTA radio/a/c mount is the same as the camaro? Like i can bolt it right up with no modding?
Old Jan 29, 2011 | 06:32 PM
Stephen's Avatar
Car: 87 GTA
I have a 87 GTA, so I've never done the swap before. So I don't know for certain that the Firebird stuff is a 100%, no mods required direct bolt-in (or what tweaks there would be needed to put one in), but I also know of no reason it wouldn't be.
Old Jan 29, 2011 | 06:37 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Well theres one way to find out. just to ask since the 4th gen consoles fit gta/firebirds better, is there a certain year/model of the 4th gen consoles that fit/look better in the gta/firebirds? Or do they all work?
Old Jan 29, 2011 | 06:48 PM
Stephen's Avatar
Car: 87 GTA
AFAIK, they all fit. BUT.....The newer you get? The more cup holders you get. I think 98, is when they put in 2 front cup holders, passenger side was a swing-out & rear cup holders, and 93-97 being just the 1 cup holder.
Old Jan 29, 2011 | 06:50 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
You don't have to use a firebird radio and heater pod. You can trim the fourth-gen console and the camaro radio pod to fit together. Been done before.
Old Jan 29, 2011 | 06:54 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Guess ill have to look at them and decide. Both 4th gen camaro and trans am consoles work right?
Old Jan 29, 2011 | 06:55 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
I know it has, but i wanted to see some pics of it. Do you have any or a link to a thread?
Old Jan 29, 2011 | 07:10 PM
Stephen's Avatar
Car: 87 GTA
Since the 3rd gen Camaro console & radio/AC mounts are 1 solid piece.....Are you saying that one can just cut the 3rd gen Camaro console in half, to separate the radio/AC mounts from it & slide the 4th gen console in under it? Keeping the 3rd gen Camaro radio/AC portion intact?
Sounds risky, cutting something in half to make it fit & not being able to resell it, when there is a solution to cutting.
Old Jan 30, 2011 | 12:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Search.
https://www.thirdgen.org/forums/body...t-console.html
Old Jan 30, 2011 | 01:32 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thanks, for some reason the message board threads dont let me go past 2010. So i really couldnt find what i needed. Thanks again
Old Jan 30, 2011 | 04:59 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i wish i had kept my old console to cut up...that really doesnt look half bad, i would REALLY like cup holders ha ha
Old Feb 7, 2011 | 07:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hey Stephen how did you get the power window switches there its because ima get one of these for $25 so ima put it in also was it a hassle to intall, also since my car is an auto and the console is for an auto too would the handle align or would i have to do some cutting?
Old Feb 7, 2011 | 07:53 PM
Stephen's Avatar
Car: 87 GTA
Not my car, so I dunno. Just looks like a flat plate made to fit the ashtray, with the stock window switches in it.
Old Feb 7, 2011 | 07:55 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh alright well ima still get it and give it a try its just $25
Old Feb 19, 2013 | 12:22 PM
travisgold's Avatar
Car: 1984 Camaro Z28
Your wrong about the 97s My 1997 Firebird had 4 Cup Holders.. So just to clarify
it would be 93 - 96 that had one cupholder.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
