Under dash hush panels.....?
Old Apr 13, 2011 | 09:14 PM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
I just bought a 1989 IROC-Z with 9,000 Original miles. She is immaculate!
I crawled on the floor and noticed I'm missing the driver and passenger side Under Dash Hush Panels. I called up the previous owner to see if he had them or if he took them off and he said no. He had no idea...
My question is:
In 1989 did all Camaro's come with the hush panels from the factory?
Or did my car not come with the hush panels from the factory??
Weird question about interior, but I got to know.
Thanks,
Tim
Old Apr 13, 2011 | 09:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Under dash hush panels.....?
All the cars had them - check ebay for cheap replacements, or else www.thirdgenranch.com
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
The passenger side I know must at least have one. The driver side isn't important because it just covers up the wires and fuse panel. The passenger side (if i'm right) is needed for the air flow for the heater. I'm not sure about whether or not it came with them though.
Old Apr 14, 2011 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not all cars were equipped with them (There seems to be no rhyme or reason behind why some cars were equipped and some weren't). With 9 K on your car, my guess is that your ride left the factory without them. Check the following link for a ton of info on the subject:
https://www.thirdgen.org/forums/hist...-plastics.html
JamesC
Old Apr 14, 2011 | 01:57 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 is completely stock and unaltered. I only have a right side hush panel.
NO left side one !
From the posts here some have 2 some have one while others have NONE!
Old Apr 14, 2011 | 03:19 PM
my82roc's Avatar
Car: 89 Iroc Convertible
If your car has the underdash lights mounted to the kick panels by little round brackets then more than likely it didnt come with hush panels.
Old Apr 14, 2011 | 03:33 PM
JamesC's Avatar
Post #10 of the link shows a pic of the above. That said, apparently some cars weren't equipped with courtesy lights.
JamesC
Old Apr 14, 2011 | 06:09 PM
Car: 1992 RS
Engine: Carbed 350
Weird - I've never seen one that didn't have them, unless the owner stated he/she had it off or broke it or lost it.
Old Apr 14, 2011 | 09:46 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The courtesy lights were part of a convenience package or light package, I don't remember. If the car has the light package and doesn't have hush panels from the factory, the lights will be mounted into a bracket. If they are just hanging by a wire, then the panels were removed. If there are no lights and no panels, then it's anybody's guess. If your ALDL still has a cover on it, then there never were and hush panels as the hush panels provided a different type of cover.
Old Apr 14, 2011 | 10:01 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 has the courtesy light on the left side mounted in a bracket attached to the bottom of the dash (NO left side hush panel)
The right side has a hush panel with a mount hole in the middle center of it and a light is mounted in that hole.
Old Apr 14, 2011 | 11:54 PM
puma1552's Avatar
I have no hush panels (I have the fuse cover), nor any courtesy lights afaik. I do have the rear view mirror with the dual map lights, though.
Car is damn dark to get in and out of at night with just the pathetic dome light.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
