Auxillary plug
Old Apr 20, 2011 | 09:39 PM
chevychevelless's Avatar
Car: 1986 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Auxillary plug
Hi, so I really need help. I once saw somewhere a picture of someone who had a cigarette lighter on the passenger side. It was located towards the center console. And I was wondering if anyone could help me out by telling me how to wire one. I have a 1986 Iroc-z with a 305tpi. I'm young and don't really know much and would like all the help I can get. Thanks.
Old Apr 21, 2011 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Auxillary plug
Welcome to TGO, chevy. Might be easier to purchase the 'adapter' that fits into the lighter, but has two outlets. Use it when you need it, remove it when you don't.
JamesC
Old Apr 21, 2011 | 12:16 PM
Car: 1986 Iroc-Z
Engine: 305 tpi
Re: Auxillary plug
Well I have one of those. But the wires just get in the way. That is my reason for trying to add a second cigarette plug. I just bought this one two days ago to plug in into the plug im asking for help on.
Old Apr 21, 2011 | 12:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Auxillary plug
In the fuse block, there will be several empty slots that are single slots (a fuse won't go into them b/c a fuse has two prongs). They are labelled with little arrows pointing to them. One will have BAT, one will have IGN, one will have LPS, one will have RADIO.
BAT = 12v+ all the time, regardless of the key
IGN = 12v+ whenever the key is turned to ON
LPS = 12v+ whenever the lights are turned on
RADIO = 12v+ whenever the key is either a) ON, or b) when at ACC setting
They accept a standard 1/4 inch male spade terminal.
So - cut the plug off your thingy there, and crimp a standard 1/4inch male spade terminal on the pos wire, and insert either into the IGN slot or the BAT slot (whichever you prefer - just remember BAT is power always, and whatever you have plugged in will draw current regardless of the key). Crimp a round connector on the neg wire, and ground it to a dash screw that goes into metal.
You might have to use butt connectors to add wire to increase the length so that you can tuck your wires away nicely under the dash.
Now, with this info, you can add all kinds of cool gadgets, extra interior lighting, radio accessories, etc.
Old Apr 21, 2011 | 01:30 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Auxillary plug
Camaronewbie is right if you are wanting to hardwire your adapter in or any cigarette lighter type plug in accessory. If using just some sort of auxilliary plug without any wires there will generally be a center terminal at the bottom that is the positive to go to the fuse box as indicated and a side terminal that is for the ground. As stated wire to a screw or small bolt going into metal for the ground. Then mount the aux plug whereever you want it. Just remember that screw holes will be left if removed so try to plan accordingly.
Old Apr 21, 2011 | 06:49 PM
Car: 1986 Iroc-Z
Engine: 305 tpi
Re: Auxillary plug
So if I hook it up in the IGN slot I won't need a fuse or anything? I just don't want to blow a fuse or fry something. But thanks a lot you guys for all the information.
Old Apr 21, 2011 | 07:25 PM
91phoenix's Avatar
Re: Auxillary plug
I would put a fuse in inline to be safe. The fuse should blow before any wiring would be damaged due to overloading or a short. I always put a fuse inline for anything.
Old Apr 21, 2011 | 07:39 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Auxillary plug
iv had this idea aswell, but adding a second cig lighter but in the back of the center console by the rear ashtray so i could use my phone charger, yes or no?
Old Apr 21, 2011 | 10:06 PM
Car: 1992 RS
Engine: Carbed 350
Re: Auxillary plug
Sure, go for it.
Sorry - should have mentioned a fuse as well - yes I'd use an inline fuse. I use a fuse for most everything, thus I don't think of mentioning it - to me a fuse is always a given.
Old Apr 22, 2011 | 09:37 AM
91phoenix's Avatar
Re: Auxillary plug
Originally Posted by camaronewbie
Sure, go for it.
I couldn't have said that any better. I feel the same using a fuse is automatic. I have only one thing in my truck that isn't fused, Winch wiring, I can get one, I may have to think outside the box, but did not feel like finding a 350-400 amp fuse. Everything else is fused, amp wiring, special radio power, driving lights, aux rear lighting, everything.
(My stereo requires the use of a 10 gauge wire for power due to the power output. It says in the manual that hooking it up to stock wiring may melt that wiring. But I like it so.)
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
