Ashtray dimensions?
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Ashtray dimensions?
Trying to make a switch panel in place of the ashtray while the car is away anybody have the dimensions its an 86 iroc center console
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Ashtray dimensions?
Im doing the same thing this weekend and will be measuing the ashtray. If you dont havew the dimentions before I do it I will send them
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
5 5/16Wx 1 3/4Lx 1/9/16H. These are of the ashtray itself (removable part). did you want the dimensions of the flip up part too?
1 Post
Car: 89 IROC
Dam thanks man as it makes it easier now to do it. Im gonna make mine like the ashtray but im going to recess it alittle shallower so its not as bad to get your fingers in it. might just hack the bottom out of a ashtray and reweld a piece to the bottom. its an option I have
I kind of want to do this too now, I would recess it so that the flip up part can cover it up.I'll get those measurements for you later today.
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Thanks, heres the pic
Alrite so i have confused myself with the measurements i needed dimensions according to the pic below also needed the dimensions of the hole where the ashtray sits i should have clarrified that in the op. I plan on making this out of plexiglass and debating on whether to light it up with leds....
Just to give you an idea. it's about 3.75" until the the flip cover.
I'm just curious as to how you'd mount them, the little lip that is there is maybe half an inch tall.
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
itll be just like how the ashtray looks and fits but with a flat bottom and made of plexiglass so i need the measurements of the red lines
1992 Trans Am
05-10-2023 07:19 PM
