Need help with Interior lighting
Old May 6, 2012 | 07:12 PM
Nappa718's Avatar
Car: 2000 Camaro Base
Engine: 3.8L v6
Transmission: Automatic
hello guys,
So i want to install my t10 blue Led's in my gauge clusters, i tryed to remove the cluster but the steering wheel gets in the way of one clip coming out, but i was also wondering does any one know how to change the bulbs in the gear selector?
Old May 6, 2012 | 09:34 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Need help with Interior lighting
You can either remove the steering wheel or drop the column. Theres 2 bolts that hold the column up. Unscrew those and it will lower down out of the way.
I think you can just remove the shift plate to get to the bulb for the gear selector.
Old May 7, 2012 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
TGO is dedicated to 82-92 Camaros. For your 2000, you might try the following site:
http://www.camaroz28.com/
Best of luck with your project.
JamesC
Old May 8, 2012 | 11:53 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Why not just take off the dash board top and reach over the top and replace the bulbs?
Much easier than pulling out the cluster or reaching up from underneath!
Old May 9, 2012 | 07:31 AM
Nappa718's Avatar
Engine: 3.8L v6
how would i go about doing this or find more information on it, i never heard of any one doing it from the dash everything i read was removing the cluster
Old May 9, 2012 | 10:52 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Just remove the 7 ? screws on the underside bottom of the dash pad and
also the 2 in each defroster vent on the top front of the dash pad up by the
windsheild.
Heres a link with instructions and a video:
https://www.thirdgen.org/forums/body...d-removal.html
Heres a pic of the back of the cluster:
Right click and open in a new window for a big pic.
Old May 9, 2012 | 11:01 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
xxxxxxxx
Old May 11, 2012 | 07:32 AM
Nappa718's Avatar
Engine: 3.8L v6
windsheild.
Alright thank you for the information and on the picture of the cluster, how many LED's would i need to just change the gauges? cause i only order 11
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
