Anyone ever change their cluster lights?
Car: 86 Trans Am
Engine: 305 HO
Transmission: 350 Turbo
I want to change my cluster lights to a different color. Has anyone done this or have any ideas? The bulbs have a slip on cover. Do they make these in different colors?
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Anyone ever change their cluster lights?
I changed all mine to clear. My covers were baked on and some were burnt. Back in the 80's we used to spray paint them with transparent colors, mainly red.
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
you can buy colored bulbs from Autozone for cheap and it is an easy install.
Looks pretty cool too.
I had blue bulbs in mine
Car: 86 Trans Am
Engine: 305 HO
Car: 86 Trans Am
Engine: 305 HO
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I got wideangle led bulbs in natural white.I hated the all orange/red of the firebird clusters.This is how it looks now without just from the leds.
I have another cluster with white overlays but it wasnt done properly and slightly off so it blocks alot of lighting.I prefer white gauge overlays in the interior but for now this is still pretty sharp looking at night.
Car: 86 Trans Am
Engine: 305 HO
Engine: 2005 LQ4
Axle/Gears: 3:54
Yea I wasnt sure how this was going to turn out but I dig the way it lights up especially the tach
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
edit: realized it's Km/H - still, looks like a lot! LOL
Last edited by Ed1LE; Dec 29, 2013 at 08:44 PM. Reason: realized it's Km/H - still, looks like a lot! LOL
Car: 1986 Iroc Z28
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
I would recommend putting in LED lights. They're much brighter and take far less energy to power.
I replaced all of my lights with LEDs a couple years back and I absolutely love the look, not to mention that my dome light actually illuminates the cabin now XD.
Here's a URL to the thread I saw that inspired my change to LEDs
https://www.thirdgen.org/forums/inte...sh-lights.html
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Engine: 5.0 EFI
Engine: 5.7, 5.0
Do all years have the gloves? I plan to ad white overlays when I ad my phantom gauges and not sure how the white faces will look with red lighting. If my '91 has the gloves tho, that should make it easy enough to remove them if I don't like the red.
Engine: 5.0 EFI
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
You can get colored bulbs without the cover too. At one time I had red on left, white in middle and blue on right. Was kinda different. Blue is very dim however. I Personally run electro-lumenicent gauge overlay now....much better looking and cheap!
I went a different route, and installed LED strips into my cluster.
Gives me a very bright and even light.
I have some pics here:
https://driiive.com/chrisfromwa/1984...!/timeline/815
Car: 91 Camaro RS 305TBI
Transmission: 7004
Axle/Gears: stock posi .373
i went with red on the tach and speedo, and white for the temp, oil, fuel.. i dig it!
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Engine: L98 494hp
I know my gauges are laid out different than the iroc gauges...but they make these for both styles just in case you were interested.....sorry for bad pic.
Engine: 2005 LQ4
Axle/Gears: 3:54
Wow forgot about this thread from awhile back lol.That cluster isnt 429k..its 42k km.I now swapped to a 140 mph cluster and re-used my leds from the previous cluster.I got the leds from superbrightleds.com iirc. I think they were the 5 led wedge 194 type. This time I also lined the inside of the cluster panel with aluminum tape to help even out the light but do like the suggestion of led strips for the same affect.
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
Word of warning!! On the models with printed gauge circuits, be mindful that some bulbs may be factory and can stick to the circuit causing it to rip and malfunction, happened to my 85 iroc cluster and it can be very aggravating, especially after reinstallation.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I've gone the blue, red LED replacement bulb route and quickly tired of these colors. I've settled on cool white
My guess is no they can't, or they can't be dimmed much because there won't be enough voltage to keep them lit.
Car: 1991 Camaro RS/z28 Clone
Engine: 305 TBI (FOR NOW)
Transmission: 700r4 =(
Axle/Gears: Stock
all the lights on my cluster went out so I decided to install some LEDs and they still don't work however, my shift plate and climate control lights still work, could it be the twist socket that may be bad? or the backing of the cluster itself which could be bad?
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Its prob. the circuit strip is prob. broken in a spot or two.
Since the shifter/hvac lights works its not a fuse/power issue.
Check the circuit board plug in..........It may just be loose.
Axle/Gears: Stock
Thanks ill check that. It was crazy they all went out one by one
Are those different coloured LED strips? Green and Blue? I really like that look!
Engine: 5.7
Transmission: 700R
I didn't change my cluster lights, but I took out the black metal trim ring that sits behind our gauge glass and painted it bright Silver and WOW! The instrument cluster really pops and is so much easier to see at night! Stone
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I changed my illum bulbs to LEDs. It looks different, not good not bad just different. It makes the orange gm used on the digital dash look almost light green.
Car: 86 chevy camaro iroc, 82 chevy k20
Engine: 305 tpi
Ebay has the led bulbs and the normal ones real cheap and in tons of colors.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yeah, and some were DOA, the rest died within months. Don't get cheap ebay LED 194 replacements! lol
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
How would this look on a 91 RS? It looks like the gauges are yellow, would per-say a green bulb actually look green, or would it just look discolored?
Axle/Gears: Stock
doubt it, I put red lights and the yellow lenses had no effect on the color going thru
ambainb
Apr 25, 2016 09:21 PM
