My L.E.D addition
Old Dec 9, 2012 | 08:24 PM
HeavyHERO93's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
My L.E.D addition
I am adding some L.E.Ds to my interior and adding them to the dimmable dash lights, need a few switches before i can finish but here are my night before shots so far.
I plan on having the leds on with my dash lights and if i want em on just in general i am adding them to a switch, but i am also adding more lights on the other side, so i am adding another switch to have both lights on, 1 light on or both off. tapping into the led that, me and my father assume is sapose to light up the shifter ***, correct me if im wrong tho.
I will have day pictures up tomorrow of how it looks atm, and i will show where we are tapping in/ adding switches. let me know what yall think!
Old Dec 10, 2012 | 11:28 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: My L.E.D addition
pretty big improvement!
Old Dec 10, 2012 | 11:54 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Looks cool man. I added LED'S to my autometer set up and what an improvment
Old Dec 10, 2012 | 08:24 PM
Car: 1991 Camaro RS
Engine: 305 TBI
i havnt added em yet, ima show it soon, father forgot to grab a switch from work so we can finish lol
Old Dec 13, 2012 | 05:29 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I warn you now, once you do LEDs it gets hard to stop. I have been slowly replacing incandescent with LEDs and adding new LEDs for around a year and a half and only have 2 more incandescent bulbs left, but it makes it look sharp. Good luck!!
Old Dec 13, 2012 | 05:37 PM
Car: 1991 Camaro RS
Engine: 305 TBI
where do you buy yours? i tryed to swap out the dash lights with 194r and found out... you really cant do that, you need to buy the hole light and mount assembly.... but im doing l.e.d strips, waiting for my father to get some time to assist, father is alot more experienced and he knows how to do stuff right haha, so i will have finished products no later than probably sunday....
Old Dec 13, 2012 | 05:52 PM
Dabesiv's Avatar
For 194 bulbs they are plug and play unless you are doing something absolutely crazy. I tried out the single diode ones from Pep Boys long ago and they are complete garbage. All my dash lights for my car and the ones I've installed in other cars are from Superbrightleds.com, I usually do the 4 diode bulbs, and paint the reflector a corresponding color, in my case red, or silver as it is highly reflective. But with a thirdgen that's newer like yours it should just be bulb replacement and the light shines through the gauge. for my strips I get them from Pep boys, Superbright has them too but I don't mind the ones PB has. I have two 4", two 12" and one 36" strips for now but might be doing two more 12" later.
My dad taught me everything I needed about electrical when we installed my first stereo, and now I teach him new tricks for it so I know how that is haha.
I highly advise to solder all joints as twist caps are a complete waste and crimps can fail easily.
Old Dec 13, 2012 | 07:58 PM
Car: 1991 Camaro RS
Engine: 305 TBI
o dont worry about doing it right, me and my father are doing solder and shrink wrap with everything haha, i am doing 2 12'' strips under the dash, i will have pictures soon, we just got done figuring out what resistors to use, we are putting them on a switch, so they are on, dimmable, or off, been one hell of a learning experience hahah!!!!!!
like i said should get finished product pictures soon, should of taken some while playing around, but can easily get some tomorrow for atleast update purposes
Old Dec 26, 2012 | 10:30 PM
Car: 1991 Camaro RS
Engine: 305 TBI
ok finally got some time, we finished the l.e.ds, we have them on the dimmer circut and i can turn em on whenever i want. for the dimmer set up, we put some resistors into the circut, looks really good, not to bright with the dimmer, but if i need to see, they light the car right up.
drivers side on dimmer/resistor
other side with resistors
full bright overview
dimmer overview
Old Dec 27, 2012 | 02:43 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
http://www.superbrightleds.com/morei...ocket/704/962/
This is what you need to install the led bulbs. GM went to a cheaper bulb/socket combo more than likely to save money. The way you have it now it washes out the gauges. If you use the sockets and bulbs it makes the numbers and needles light up red. I used the five led wedge bulbs on mine bellow.
Old Dec 27, 2012 | 04:08 AM
Dabesiv's Avatar
dimmer overview
IMHO, that is way too bright to even be comfortable. I can understand doing interior lights under the dash pad for a courtesy light but something that bright shouldn't be on all the time. Red is great because it doesn't effect your night vision like say green or white would, but I think this would be more distracting. But to each man his own desires, so if it's what floats your boat then go for it.
Old Dec 27, 2012 | 04:55 AM
cdoyle's Avatar
Ya I think you really need to backlight them instead, right now that's just too much light in the cabin when you're driving.
Here are mine after I did the LEDs
Old Dec 27, 2012 | 09:02 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
cdoyle was this just using the wide angle 194's? I like the look!
Old Dec 27, 2012 | 09:17 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Yours came out nice, clear and crisp.
Old Dec 27, 2012 | 09:42 AM
cdoyle's Avatar
I actually used LED strips and placed them behind the numbers to give me a really uniform look.
It takes more work, but I think it turns out better than the plug/play lights.
Old Dec 27, 2012 | 10:48 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Smart move! I just ordered a set of overlays from ebay and i'll be installing those soon. They were on a thread earlier in the year and finally seen another set pop up!
Old Dec 27, 2012 | 01:32 PM
Dabesiv's Avatar
wow, I like that cool white too, very crisp!
this is my dash with red. Name:  IMAG1276.jpg
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
blackz281le
Jan 11, 2016 07:51 AM
Giocio
Oct 1, 2015 12:20 PM
WhteRbt
Sep 21, 2015 09:48 AM
