anyone used a dash pad cover
Old Apr 1, 2013 | 08:44 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
something like this
and by the way where is the speaker holes
http://www.ebay.com/itm/NEW-Molded-D...fe753f&vxp=mtr
Old Apr 1, 2013 | 08:55 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: anyone used a dash pad cover
They look great,but the speaker holes are molded into the cover, their not like original.
Make sure you order one for your year if they come like that,I bought one and got one for the 82-84 style,not sure if they come any different.
This is the 82-84 style.
Old Apr 2, 2013 | 12:11 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
You can find ones with speaker holes, theres different ones out there, the one you have posted has holes in the pic, it may work out.
Old Apr 2, 2013 | 02:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
They do,the holes are right on top of the speakers.
Old Apr 2, 2013 | 04:38 PM
jamon8's Avatar
Engine: 350 tpi
manta yours looks like the speaker holes are not there. I would like to find one that had the speaker holes in it already. either that or put a really nice set of speakers in before I put the dash cover down.
dont you have to glue down the dash pad cover
Old Apr 2, 2013 | 04:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yea their there,their molded into the cover.Yes you have to glue the cover down,you can do it in the car or out,just make sure you don't don't cover the screws in the defrost vent.
Old Apr 2, 2013 | 04:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Here's a better pic I found,you can see the speaker holes.
Old Apr 2, 2013 | 05:36 PM
BADNBLK's Avatar
COTM Editor
I used on, but smoothed and painted it. Mine warped in the sun badly in the staging lanes at the dragstrip. I did NOT glue mine as it was a cover for the perfect factory dash I didn't want to mess up... long story short. The warped cover cracked my mint dash pad.
I think that they fit nice and tight, but I would totally recommend glueing it down to the dash as directions recommend
Old Apr 2, 2013 | 06:01 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Nice id never guess there was a cover on that dash, well from the pictures. I just bought one from a local guy who wrecked his 88 with 60k on it luckily i got it for $100 in very good shape
Old Apr 2, 2013 | 07:23 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
They are ok for a quick fix on a tight budget. I just dabbed the silicone adhesive in a few spots four years ago to stop the rattling and it held up great.
Old Apr 4, 2013 | 12:42 PM
1Aauto's Avatar
Former Sponsor
We carry them on our website. Here's a link to them and also a video from one of the members on the board.
Dash Pads on out site
http://www.1aauto.com/1A/Dash_Pad_Co...ampaign=1ATony
Old May 2, 2013 | 08:53 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
A few years ago I bought one from Hawks Third Gen looks OK but obviously a cover to a third gen expert. I did not glue it down and it does not rattle nor move but I would love to buy a nice factory pad if I found one cheaper than the 450+ that Classic wants.
Old May 3, 2013 | 02:48 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
I bought the one from 1A auto. I installed it with the dash pad out of the car. It is not cut very good and I had to shave some plastic off the cap, so the whole dash would seat properly. All the fighting I had to do with it even caused a little crack in the corner of the cap . I fixed it from the backside with a little JB weld. There is a walk through of the cap install on this website I believe, but its not the cap from 1A. I was prepared to drill the holes for the screws in the defroster vent like the guy did in the sticky, but when I test fit the cap, it didn't go the whole way into the defroster vent (it stopped right above the screws). I guess they did that so you could access the screws later on if you wanted to remove the dash pad, cause the caps are made to install without removing the dash pad. That was a mistake, because you could see the old crappy dash down in the vent. So I had to strip all the old dash pad out of the vents. It is sheet metal underneath. Then I painted it silver and then installed the pad. It looks awesome now, just a silver ring around the bottom of the defroster vents, but it was alot of work. Then the little side vents didn't fit what so ever. I had to carefully trim the bottom of the vents to make them more shallow and use a couple dots of black silicone to glue the vents in the holes (you can't tell). Like I said it looks perfect now, but it wasn't as easy as I thought it was gonna be. DEFINITLY get a good quality cap. Try to find the one the guy used in the sticky thread, he says where he bought it. I paid like 150 for the one at 1A, and I had a tough time installing it. So I can only imagine how crappy a cheap ebay one would be. Sorry for the huge post... Oh, and I did glue mine down like the instuctions say, and used painters tape to hold it firm to the pad while the glue cured (like the guys shows in the sticky)
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
