hatch release wont bolt up
Old Dec 28, 2013 | 06:26 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
i just bought a release asembly with motor and stuff off a 91 firebird for my 92 when i got home i found the bolt holes dont line up at all they dont match up and the plugs are completely diferent whats up with this i need some sort of locking mechanism for my hatch please help
Old Dec 28, 2013 | 06:33 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: hatch release wont bolt up
late 91 through 1992 year models had competely different pull-down mechanisms. Check out top-downsolutions.com, Lon is a member here and sells parts as well as rebuilt units of each kind.
Old Dec 28, 2013 | 07:10 PM
mikey8494's Avatar
Axle/Gears: stock
so theres no way to make it work
Old Dec 28, 2013 | 07:17 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
no...no way to make it work...unless you want to grind off the old mount then grind one off of the 86-91 and weld it on your car.
Old Dec 28, 2013 | 07:26 PM
mikey8494's Avatar
Axle/Gears: stock
i got this unit for 7 bucks i dont have 383 bucks for a unit
Old Dec 28, 2013 | 07:28 PM
mikey8494's Avatar
Axle/Gears: stock
i barely have 60 bucks to dump on one of these things
Old Dec 28, 2013 | 07:40 PM
Joe Tag's Avatar
You can't put your old unit on until you can spring for a rebuild kit? I think they're like $100. Take the part back to the yard and see if they have the right one? I feel your pain buddy, but when you're fixing up a nearly antique car, you are going to pay IF you can find the parts.
Old Dec 28, 2013 | 07:45 PM
mikey8494's Avatar
Axle/Gears: stock
when i bought the car it didnt have anything at all it has no unit at all so my hatch is open to anyone walking by the po doesnt even know were it is and wont get it for me
Old Dec 28, 2013 | 07:56 PM
Joe Tag's Avatar
I once had the idea to get the latch and mounting bracket out of an 82-84 and have it welded in my car. These units are so prone to breaking and not going to get any cheaper or easier to find. I got a used unit and will baby it until it needs replaced again.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
