Firebird overhead console
Old Nov 8, 2014 | 01:38 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Hey I got a question. Will the overhead console on a 87 Trans Am fit on a 89 GTA? I'd rather replace my overhead headliner with that instead.
Old Nov 8, 2014 | 02:43 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Firebird overhead console
Yes it will fit as long as they are both T-tops or both hardtops.
Old Nov 8, 2014 | 05:30 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
There are six ( I believe ) T studs that you will need to secure the console. Easy if you have those.
Old Nov 8, 2014 | 06:30 PM
There are four of the special bolts, but they should already be present if he's removing the console from another car.
Old Nov 8, 2014 | 08:20 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
This is the item I was talking about.
http://m.ebay.com/itm/251706081970?nav=WATCHING_ACTIVEhttp://m.ebay.com/itm/370970102356?nav=WATCHING_ACTIVEWill I need to cut my headliner to fit it in? I need to replace my headliner anyways, but I wanted to know beforehand. Also my car has T Tops so will it work with my car? Reason I ask is I have seen cars with t-tops that have the very same center console.
Old Nov 8, 2014 | 08:55 PM
Read this first:
https://www.thirdgen.org/forums/faq-...oth-types.html
Old Nov 8, 2014 | 09:24 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Originally Posted by blacksunshine'91
None of the pictures work anymore in that link.
Old Nov 8, 2014 | 09:27 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Yes the head liner needs to be cut for it. There were two differant consoles, one for hardtops and one for t-tops (i believe the hardtop versions had a slight curve to them. As long as youre going from t-top to t-top you should be fine.
Old Nov 8, 2014 | 09:31 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Ok... Well I guess I need to find the right console first then.
Old Nov 8, 2014 | 09:33 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The pics work if you are logged in, but even if they didn't, the text has useful information like the difference in mounting slot positions.
IIRC the T-Tops also require the additional piece in the pic below.
Old Nov 9, 2014 | 09:22 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
What IS that piece in the bottom of the photo? I've never seen that before.
Old Nov 9, 2014 | 01:26 PM
Scorpner's Avatar
Engine: V6, V8
It should be explained in the link blacksunshine'91 posted. I think it was used on the T-Top version for additional support. -Actually it might be the other way around. It's been a while since I dealt with it.
Here is the link that explains it:
Old Nov 9, 2014 | 06:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
This is what your headliner looks like with the OH Console.
Old Nov 9, 2014 | 08:50 PM
DynoDave43's Avatar
Coupe only, according to that. Thanks.
Old Nov 9, 2014 | 09:44 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I have done this mod. To do it, you need the console, wiring pigtail, and mounting studs. You will need to cut your overhead liner to fit the console (there is a tech article or google it). The holes for the mounting studs are (should) already be in the roof structure. Simply screw the studs into the holes. Wire up the pigtail, mount, ad your done.
Now, if you wanna get real schnazzy, get a garage door opener out of a 2000 Coupe De Ville. Fits perfectly in the spot for the flashlight. I have done this also.
Old Nov 10, 2014 | 06:02 AM
DynoDave43's Avatar
I remember that. That Homelink unit is self contained, right? You are just bringing it power and ground?
Old Nov 10, 2014 | 08:15 AM
Veaceonee's Avatar
yup. Orange wire (I think) is constant hot, then black to ground. Done. It is kinda awkward reaching behind you to open the garage door, but you get used to it.
Old Nov 10, 2014 | 10:04 AM
RavenGT's Avatar
Car: 1996 Firebird
Engine: 3800 Series II
Transmission: 4-speed Manual w/ OD
Make sure you get the right Homelink. They have red or amber lights, and which one to use depends on your garage door. The amber is the "rolling code".
I have the Homelink in my OHC - which I installed in a 96 Firebird.
Old Nov 10, 2014 | 10:13 AM
Veaceonee's Avatar
Originally Posted by RavenGT
Make sure you get the right Homelink. They have red or amber lights, and which one to use depends on your garage door. The amber is the "rolling code". .
Details details.
Old Nov 10, 2014 | 12:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Here's that link,
https://www.thirdgen.org/step-by-ste...e-installation
Old Nov 10, 2014 | 07:36 PM
RavenGT's Avatar
Car: 1996 Firebird
Homelink mod -
https://www.thirdgen.org/forums/inte...ml#post5769859
Old Nov 10, 2014 | 11:15 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Well the garage door opener would be nice if I had a garage to put the car in. Only have a driveway here.
Old Nov 11, 2014 | 06:57 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Here's some close-ups of what you need to go through to install the console:
https://www.thirdgen.org/forums/memb...ml#post5729917
Old Nov 11, 2014 | 09:11 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
https://www.thirdgen.org/forums/inte...ll-wiring.html
Just more reference...
J.
Old Nov 11, 2014 | 05:04 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Good one! Wish I had seen that when I got started!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
mav75
Aug 31, 2015 12:16 AM
TheJoeY88
Aug 13, 2015 06:51 PM
