Removing the dash pad
Old Nov 10, 2015 | 09:12 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I have a perfect dash pad in my 91. I need new speakers as mine are shot. Does anyone see a problem in replacing the speakers. I am worried about the pad cracking. Should I be concerned as it is 24 yrs old?
thanks
Old Nov 10, 2015 | 10:02 AM
LC2 TECH's Avatar
Re: Removing the dash pad
If it is a well care for dash there should be no problems. There is always a risk with 24yr old plastics. The most common issue is when people are installing it and over tighten the screws.
Old Nov 10, 2015 | 10:54 AM
vinny R's Avatar
Car: 1991 Z28
Thanks LC2 tech
Old Nov 11, 2015 | 10:45 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
WARNING!
Don't forget the 4 screws (2 in each side) in the defrost vent openings!
Old Nov 13, 2015 | 12:36 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ive removed my 84 dashpad many times & never cracked it.Sometimes not so gently either.
Old Nov 13, 2015 | 05:33 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Like LC2 Tech said above - do not try to get every last turn out of the screws when you put it back in. Make it tight enough, but do not tighten it all the way down.
Old Nov 13, 2015 | 09:55 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I would worry more if you were in a colder climate but seeing you're in FL, I'd worry more about the sun affecting it over time.
Old Nov 13, 2015 | 07:06 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Do it all of the time too. Six 7mm bolts on the bottom and four Phillips screws in the defrost vents.
Old Nov 14, 2015 | 08:13 AM
vinny R's Avatar
Car: 1991 Z28
Thanks guys
It came out and went back with no problems. Put some JBL's in and can fade to front speakers again!
I have an old school Dash Mat to help protect from that So Flo sun and she sits in a garage all day.
StevenJ153
Mar 6, 2016 09:59 PM
bbc632
Nov 17, 2015 01:15 PM
Agent13
Firebirds Wanted
Nov 11, 2015 08:28 PM
Redwhisper
Nov 8, 2015 02:55 PM
Stevolwevol
Nov 5, 2015 01:37 PM
