GTA seat question
Old Sep 24, 2018 | 06:24 PM
Elmars Romeiko's Avatar
GTA seat question
Hi guys,
wanted to ask if these are the correct seats for my 1989 Pontiac Trans AM GTA in front and in rear? because front seats have some kind of control in side
and under the seat are wires but there is no wires to connect them.. SO i think they are from other model.
and if there is possibilities to connect them to my car?
Old Sep 24, 2018 | 06:46 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: GTA seat question
Originally Posted by Elmars Romeiko
Hi guys,
Looks like 4th gen seats, is the base manual ir power? U could get another base and swap it for a power one
Old Sep 24, 2018 | 06:55 PM
mwill316's Avatar
Car: '88 GTA
These are 4th gen seats
Old Sep 24, 2018 | 07:29 PM
oki, so if they are 4gen seats, can i make them work on my car? or i need all wires and base new
because base is manual and i can move them manual!!
Old Sep 24, 2018 | 07:46 PM
Lakerman62's Avatar
Yes, get a oowwp power base from third gen and swap em out, or get a 4th gen and connect the power wire to the one coming out from under the carpet......
Old Sep 25, 2018 | 11:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If his car didn't already have power seats there won't be the power for him to connect to.
If your car was non-power, you'll have to run a new wire from the accessory circuit for the power seats, it is a heavy wire. its a 10 or 12 gauge wire, would be Orange coming from under the LH kick panel area. This will work the power for the seat tracks, but not the inflatable lumbar or side supports. You need the air tube that comes from the passenger side. It's easier to just buy the harness and hook it all up
Old Sep 27, 2018 | 02:43 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Those seats are out of a 1993-97 Firebird/Formula/Trans Am, as they still have the manually adjustable lower cushion, and a 4th gen style headrest.
What's odd about them is the fact that they don't have the large headrests that were used from 1993-97. I've seen this style of seat in a few 1993-97 cars, but still can't figure out why some got the large headrests, while others got the small headrests that were on all 1998-02 cars.
Old Oct 1, 2018 | 12:22 AM
jrevans's Avatar
Car: '95 T/A
I gotta agree with you on this. I used to have an 89 GTA and the pictures here don't match what mine used to look like.
I have a 95 T/A now, and my seat bottoms match what is shown in those pictures, but the small headrests confuse me. I have never seem the small headrests before. Interesting!
Old Oct 1, 2018 | 03:13 PM
got the car form japan
Old Oct 1, 2018 | 03:34 PM
Drew's Avatar
The small headrests were used in the early 4th gens. Usually see them on base Firebirds and Formulas, less often on Trans Ams. Either way, they're 4th gen seats. Aside from the headrests they're pretty closely related to the thirdgen Ultima seats.
The Ultima seats and early 4th gen seats both used a manual base mechanism. The power harness is solely for the inflatable lumbar support. The motor assembly is mounted to one seat, an air hose and wiring connects the seats together to supply air to the second seat, and to connect the switches on the second seat to the motor on the primary. The wiring between the car and the seat(s) is simple, GM just used a male/female connector set that plugs in between the dash harness and power window harness, and T's the power out to the seats, along with a ground. The power source is there regardless if the car has crank windows or power windows, it's just a matter of plugging the seat harness into the car.
A lazy person with the pigtails for the seats can wire them up pretty easily without the stock harness, but it's a lot easier if you have the uncut harness.
Old Oct 1, 2018 | 09:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Still need the air tube that goes between or there's no point with the manual bottoms really
Old Oct 2, 2018 | 02:35 AM
Drew's Avatar
True, when I cut the pigtails from the donor car (19 years ago) I clipped the hose ends too. :P If I were pulling a set now, I'd cut the carpet and pull the harness in one piece...
Eric-86sc
Apr 13, 2014 10:32 PM
Hartmann
Mar 27, 2009 09:07 PM
Night Hawk
Aug 17, 2004 05:19 PM
86IROCMIKE
Dec 30, 2000 06:22 PM
