How do you change this light..look inside
Old Apr 24, 2020 | 06:42 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Good evening. This is the light thats shines over the HVAC and it doesn't come on anymore. How to you check or change the bulb
Old Apr 24, 2020 | 09:00 PM
Drew's Avatar
Re: How do you change this light..look inside
You unplug it from the harness and plug in a new one. It's a sealed light, the bulb itself isn't serviceable.
Old Apr 26, 2020 | 09:25 PM
TOM305T/A's Avatar
thanks alot those replacements lights are hard to come by
Old Apr 26, 2020 | 09:30 PM
Drew's Avatar
Could always install anything from a headlight switch light, to a marker light socket, or an LED to do the same thing. It shouldn't be a very bright light in stock form, the tinyest LED will be in danger of casting too much light.
Old Apr 29, 2020 | 10:12 AM
j.jacob's Avatar
Also you can change stangart light on tiniest LED
Old Apr 29, 2020 | 08:18 PM
TOM305T/A's Avatar
yeah,i dont want anything to bright and i want it to angle downwards towards hvac
Old Apr 29, 2020 | 09:08 PM
Drew's Avatar
It's the stubby bit the pink arrow is pointing at, right? That pic is about 20 years old, but that dash shell is still in my attic. I might have to dig into the attic and see if the light is still there.
An alternative would be to install the rear view mirror from a later Firebird. When GM redesigned the dash for the airbag in 1990, they put a provision for a small light in the bottom of the accessory switch panel, but most Firebirds don't actually have a light there. Instead they've got a tiny bulb in the rear view mirror that takes the place of one of the map light switches, and the light shines on the shifter/HVAC/Radio, and ash tray.
It wouldn't be too hard to add the rear view mirror light on an earlier car. Just tap into one of the gray illumination wires in the dash harness, and extend it up the A-pillar with the domelight wiring over to the middle. Then add a ground wire in the center of the roof, that covers two of the four wires, the other two are just spliced into the existing orange and white wires to the dome light. That way the map lights come on with the dome light, or the switch, and the ashtray light comes on with the dash lights.
Old Apr 29, 2020 | 09:50 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
If you can't fined one, contact firebirddude142, he probably has a few of them somewhere. Now, I'm thinking about buying a couple of extra, I mean geez, if you can't replace the bulb, then that's a problem. Another GM better idea. These cars are full of those.
Old Apr 29, 2020 | 10:17 PM
Drew's Avatar
I'm pretty sure it's neon, or halogen, or one of those... Should be good for the life of the car. Kind of like the one above the headlight switch.
The book shows the Lamp, ashtray with the part number printed on the housing in OP's photo as 87-89. Which makes me wonder, the dash in my pic is from an 86, and as best I can tell it has or had the same light in it. Hmm.
Old Apr 29, 2020 | 11:25 PM
Drew's Avatar
I'm not sure how that light clips into the dash, but maybe something like this LED license plate bolt lights would work? If they're too bright you could always add a colored plastic filter lens to dim them down and change the color. Orange soda bottle might be one way to make it work.
Old May 1, 2020 | 07:22 PM
TOM305T/A's Avatar
thanks guys, 2 good suggestions. i really appreciate the info
blktransam
Jul 2, 2015 05:55 PM
84 1LE
Jan 11, 2015 10:57 AM
rodsatheart
Sep 4, 2013 01:59 AM
nastynate6
May 1, 2010 04:56 PM
83TransAmGirl
Southern California Area
Oct 2, 2003 10:07 PM
