The 92 RS High Beam Switch
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
The high beam lever on the steering column is jammed. (3rd Gen RS) I did notice that if I moved the tilt wheel up or down it works. But that won't help when driving.
Is the problem in the column? easy fix?
I did do a search first, new layout is nice gotta get used to it.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: The 92 RS High Beam Switch
You mean jammed like stuck in place or just doesn't work. Could be the switch which is down the column and actuated by a rod just needs adjusting to tighten any slack. Sometimes tilting up or down makes it work better but hard to do while driving...
Engine: 305 & 6.2L
This was the problem and it's now finally resolved. Next time, I won't take the inspection guy's word for it. Blew it way out of proportion.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Cool, the one on my car was hardly working and I also found the solution here. Success is good!
