more thirdgen ls1 photos
Old Aug 22, 2007 | 09:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
here are some. I still have to do some cleaning under the hood. I also plan to remove the valve covers and strip them clean or blast them and give them a shot of black paint. install the a/c and cruise control are also comming up next.
Attached Thumbnails more thirdgen ls1 photos-im000841.jpg   more thirdgen ls1 photos-im000842.jpg
Old Aug 22, 2007 | 09:48 PM
Engine: ls1, LB9
Re: more thirdgen ls1 photos
some more
Attached Thumbnails more thirdgen ls1 photos-im000843.jpg   more thirdgen ls1 photos-im000843a.jpg
Old Aug 23, 2007 | 09:16 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Nice job! I assume you have it up and running?? How do ya like it?
Are you ditching the a/c or are you gonna make it work?
J.
Old Aug 23, 2007 | 01:33 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Nice install!
Old Aug 23, 2007 | 01:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do you plan on putting the PCM on the otherside of the firewall?
Old Aug 23, 2007 | 09:33 PM
Engine: ls1, LB9
thanks guys, I have driven it several times. I like it!
I miss the lopey idle and how hard my old combo pulled but the drivability of the ls1 is well worth it and I can get the same performance down the road and the ls1 will still have better manners on top of it. not to mention it's kinda a sleeper now
I plan to hook the a/c up once I get a compressor and a new dryer. I plan make this thing a real daily driver.
the pcm will stay out under the hood. although the pictures make it look close to several things like the manifold but it's not. well the air intake it very close but everything else is pretty far away.
I just have so much cleaning up to do under the hood
I will have to get some new tires too, these are several years old now = not safe
Old Aug 23, 2007 | 09:40 PM
Engine: ls1, LB9
here is a picture of the outside, I took this last year but it still looks the same. I kept the stock int.
I also have the donor bcm still which I plan to hook up the door locks, hatch release. I also plan to run the Park lights, horn and run the factory vats from it. so I will have the keyless entry setup like the 4th gens
Attached Thumbnails more thirdgen ls1 photos-picture-039.jpg   more thirdgen ls1 photos-im000846.jpg
Old Sep 5, 2007 | 09:53 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
SWEET lookin' car! And yeah, I'd probably never suspect that it had anything more than about 300 hp...
Frozer!!!
Jan 19, 2024 04:55 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
BBSDesigns
Aug 11, 2015 07:39 PM
