battery sparking
Old Feb 14, 2010 | 11:18 PM
oners2nv's Avatar
Car: 1992 Z28
Engine: Magnacharged heads cam lq4
Axle/Gears: strange s60 4.10
battery sparking
I just finished my ls1 swap and I went to hook up the positive battery cable and it sparked really bad. I hooked up the negative first then the positive. Any reason the battery would spark so bad?
Old Feb 15, 2010 | 03:48 AM
Pocket's Avatar
Car: 91 Trans Am
Re: battery sparking
You have a draw from electronics being set to 12v constant instead of 12v IGN. Youll have to sort these out or your battery will drain
Old Feb 15, 2010 | 07:28 AM
oners2nv's Avatar
Car: 1992 Z28
I emailed Speartech to see what he thought, but have not heard from him yet. He is who I got my TPI harness reworked and the ls1 harness from. This sucks I am so close to starting it up.
Old Feb 15, 2010 | 08:59 AM
Pocket's Avatar
Car: 91 Trans Am
Try to figure out what is powering up when the battery goes on
Listen for clicks and hums. Be sure the key is off too, you dont want to go chasing your tail if the IGN is on
Common suspects are the PCM/INJ fuses are connected to 12v battery instead of IGN. Hook up the battery and check for 12v at each with the key off. They should have nothing on them
Old Feb 15, 2010 | 09:33 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
positive gets hooked up first, then ground. safety first!
Old Feb 15, 2010 | 10:06 AM
hatemail72's Avatar
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
positive gets hooked up first then the ground and vise virsa when un hooking
Old Feb 15, 2010 | 11:57 AM
oners2nv's Avatar
Car: 1992 Z28
I just got an email back from John at Speartech and this is exactly what he told me in the email.... "That sounds like one of the battery hookup wires is touching ground. Double check that all of the main battery wires around the battery, starter, and junction block were not accidentally bolted to ground. Since they have ring terminals on them, some assume they go to ground, when they are really positive battery wires.
I've also seen the ring terminals rotate as the bolt or nut is tightened, sometimes allowing them to touch something metal (ground) when the bolt gets tight."
Old Feb 15, 2010 | 01:19 PM
Pocket's Avatar
Car: 91 Trans Am
Ring terminals should be few and far between. You have 2-5 for the power distribution block, whether or not thats still on the starter
One alt lug and 2-3 grounds on the rear of the cyl heads
Old Feb 15, 2010 | 07:04 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Mine did the same exact thing, turns out it was the rubber boot at the end of the positive cable, where it hooks up to the starter, was cracked. It was making the copper wires inside the cable be exposed and touch the side of the starter which caused a direct ground. Check all your cables and make sure they are secured and that nothing is grounding itself out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
85cmroz28
Oct 4, 2015 09:44 PM
camarohelp
Sep 22, 2015 03:19 PM
