Alternator wiring help
Old Aug 18, 2010 | 01:19 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
I'm just finishing up my 89 RS / LQ4/ MP-T76 build and I realized that the previous owner didn't even have the alternator wired to anything. The wires just went into the harness and didn't go anywhere.
I'm using a harness from a 01 or 02 F-body and PCM and need to know how to wire this thing up. Any help would be greatly appreciated. I posted this question on LS1 tech as well.
Attached Thumbnails Alternator wiring help-dsc01423.jpg   Alternator wiring help-dsc01424.jpg   Alternator wiring help-dsc01425.jpg
Old Aug 18, 2010 | 02:39 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Alternator wiring help
The f-body harness will have only one wire in the plug, and one that goes into the back which is 12v.
Old Aug 18, 2010 | 02:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
so your going to use the alt. from a pre lsx?
terminal F is hot in run power
terminal S is hot all times... starter cable or battery.. (voltage sensing)
the big stud goes to battery for charging
Old Aug 18, 2010 | 03:09 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Well, I planned on using it if possible. Will it not work?
Please forgive me for not quite understanding what you are telling me about terminal F & S.
I assume I would run the lug labeled bat to either the starter, a dist. block or straight back to the battery. I just need to understand how to tie the other two leads either into the LS harness or the chasis harness.
Old Aug 18, 2010 | 03:11 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Again I'm not as stupid as I may appear right now but I still don't get what you are saying.
Old Aug 18, 2010 | 04:41 PM
Engine: ls1, LB9
the connector on your alt. has a tan wire and a red wire.. they should be labled as F and S some were on the connector housing or alt side of the connector (FYI that 01-02 harness wont control that alt.)
as for using it with the ls1 eng. it would work just fine as long as you make a bracket or somehow mod the lsx one
Old Aug 18, 2010 | 06:39 PM
Pocket's Avatar
Car: 91 Trans Am
Thats the 3rd gen alt and your 89 connector
This is correct
Run the S (red) to the power dist block whether its stock on the starter lug or remote
Run F (Tan/wht) to C207 pin D (Tan/wht)
3rd gens mix the Alt and fan fuse into one point for some reason
You wont be able to use the old alt in the new LS1 bracket. IIRC the pulley depth is incorrect. Anything you do will be custom
Old Aug 18, 2010 | 07:08 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
This is correct
Ok got it! BTW I have already made my bracket to mount it I just wasn't quite sure how to hook it up.
Old Aug 19, 2010 | 09:13 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Well, problem solved. My idiot light didn't work so I jusy wired a 100 ohm resistor to the tan wire and bam! Thanks for the help.
Old Aug 28, 2010 | 10:54 PM
adamwbennett's Avatar
I recently went through this with a 88 camaro and a 95 lt1. I know atleast mine required a 470 ohm resistor. I tried several 100 ohm resistors and ended up subsequently changing several alternators!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
