shorty headers for ls1,2,3,ect.
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
bbk and edelbrock make shorty headers make for the 10 camaro, i was just wondering if anyone has tried these on there ls1 swap on there third gen.to see if it would fit ..i know i rather have the LT headers but just a thought...
bbk
http://www.jegs.com/i/BBK+Performanc.../4020/10002/-1
edelbrock
http://www.jegs.com/i/Edelbrock/350/65712/10002/-1
i do like the edelbrock shortys just wish the primary tube/collector was bigger like the ones from bbk
bbk
edelbrock
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: shorty headers for ls1,2,3,ect.
looks like it could work, especially with a 3rd gen stock style exhaust routing
dont have all the angles though, not sure if hte collectors would hit the steering shaft. it almost looks like the collectors are aiming out, which would not work
#5&6 plug look pretty rough to get to with the BBK headers
I dont see a whole lot of difference in those headers vs the 98-02 Fbody shorties. I like how the BBKs label the manifolds as "restrictive" even though they are essentially a cast version of BBKs header
Car: 1987 Trans Am
Engine: LQ9/L92
you'd probably have better luck (and lower costs) by sticking with 4th gen shorties. more vendor out there, we know the stock mani's fit no problem, probably some used ones out there too for little cash
Car: 88' Iroc-Z
Engine: LQ9
for an ls1 people recommend getting a set of 01-02 fbody manifolds. they flow almost just as well as the aftermarket shorty headers. so stock manifolds or long tubes would be the way to go for an exhaust
Car: 1987 Trans Am
Engine: LQ9/L92
this is the route i'm going. just grabbed a set off craigslist for $50.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have a set of 10 camaro manifolds, when i do the swap in my 86 TA i will see if the fit right, but they are for doing a turbo project on the car.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
I tried a set of them when I first did my swap and they did not work. The dumps were right on top of the k member.
Car: 1984 Trans Am
Wow, I was really looking at getting set of 2010 camaro manifolds but with this...damn. I figured they'd basically be the same as the3 98-02 versions based on how they look.
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Yeah that is what I originally thought too. But the 98-02 manifolds kick back further than the 2010 manifolds.
