ls1 fuelpump third gen conversion????
Old Dec 2, 2011 | 11:00 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
have a little problem figuring out what pump i need for my 3rd gen conversion... have the regulater and the lines got them from hawks... just cant seem to find out what pump i need??? any advice would help...
Old Dec 3, 2011 | 06:25 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 fuelpump third gen conversion????
Which tank/sender are you using?
Old Dec 8, 2011 | 09:50 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
the 88 fuel tank and sendin unit....
Old Dec 8, 2011 | 10:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the walbro 255 is a pretty common pump of choice
Old Dec 8, 2011 | 10:51 PM
gp90gta's Avatar
Car: 1990 GTA
Or you can use the GM Syclone one, parts# 25163473 or the Ac-delco part# ep381, its rated at 50gph at 55psi.
Old Dec 8, 2011 | 11:05 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
thanks ive heard about that walbro 255 .... whats the diffrence between gss340 and gss340m????
Old Dec 8, 2011 | 11:08 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
ima look in to yhat gm one thanks!!!!!!!!!!
Old Dec 9, 2011 | 07:16 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
There is a group purchase on ls1tech for a Walbro 255 for like 105 shipped I think. Might want to check those out. Probably cheaper than GM stuff.
Old Dec 10, 2011 | 12:03 PM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
thanks everyone!!!!!! just got my mounts in from hawks.....
Old Jun 5, 2020 | 09:43 AM
ARthe1's Avatar
Would the fuel pump that comes with the tpi cars work ??
Old Jun 5, 2020 | 11:11 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
No.
Old Jun 5, 2020 | 11:26 AM
gp90gta's Avatar
Car: 1990 GTA
Yeah I think it’s good idea to just upgrade especially if it’s an older pump.
Old Jun 5, 2020 | 11:35 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
LS stuff runs at slightly higher pressures. Pumps for basic ls swaps are cheap. Labor will cost you more (either DIY or if you farm it out)
Old Jun 5, 2020 | 12:51 PM
gp90gta's Avatar
Car: 1990 GTA
Yes thanks but I was replying to the question, I don’t do LS bro that’s all Jon.
Old Jun 5, 2020 | 01:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No worries. I actually meant to expand on my initial short answer and quote the other poster.
Old Jun 5, 2020 | 06:58 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
The fuel pump for the '96-'98 Vortec* pickups is a 4-bar (58 psi) pump.
That's what I'm going to use.
*To me, these will always be the "Vortec" engines; everything else is an LS.
DerrenZ
Apr 23, 2014 11:02 AM
92RS4US
Jun 6, 2013 06:18 AM
Shift06
Sep 3, 2009 05:55 PM
Z 2 L8ter
May 22, 2006 11:48 AM
bac67
Aug 11, 2005 10:45 PM
