4L60E tailshaft housing on 700R4?
Old Sep 28, 2016 | 11:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I'm looking to do this so I can use the 4L60E swap crossmember since the mount points are roughly 2 inches farther back on the 4L60e than the 700R4. Has anyone one this or seen it done?
Old Sep 28, 2016 | 11:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 4L60E tailshaft housing on 700R4?
If I understand you correctly, i don't think you can do what you're thinking.
The early 4l60e is the same tail shaft bolt pattern as the 4l60/700r4 with the same mounting point.
The later LS style trans has a 6 bolt tail shaft mounting pattern and wont fit the early trans.
I just googled the images to see the differences
Old Sep 28, 2016 | 12:03 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
found this over on tech, don't know if it helps any or not. http://ls1tech.com/forums/automatic-...ail-shaft.html
Old Sep 28, 2016 | 01:32 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks for the link! It helps, kind of. I wish I had bookmarked where I read that there was an adapter. What year did they change the mount design to the 6 bolt? Was it 98? did they change the mounting points at the same time?
Old Sep 28, 2016 | 03:22 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Alternately, can I just use my stock transmission cross member? From the research I have done, I don't think so because the LS motors sit back farther? Or do they only sit back farther because they're shorter?
Old Sep 28, 2016 | 05:32 PM
TTOP350's Avatar
The transmissions are interchangeable between 3rd and 4thgens without messing with the driveshafts and tq arms. soo nothing has really "moved"
Old Sep 29, 2016 | 03:58 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if you want to retain the 700R4 and your stock crossmember, you will need 1" setback plates. LSX motors actually sit more forward than LT1's and earlier small blocks. third and 4th gen transmissions interchange only depending on the combo. the 4L60E with the bolt on bell housing the LSX motors use is longer than the LT1 version and the 700R4 as well as having the mount in a different place. if you are sticking with your 700R4, get 1" setback plates, use your factory motor mounts with them, and keep the 700R4 crossmember.
Old Sep 29, 2016 | 07:55 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Thank you! That's the kind of information I was looking for. So I can use my stock cross member, I just need the set back plates for the motor mounts.
I picked these Spohn LS swap motor mounts up, will they work as the "setback" mounts that you're talking about? Or do I need the set back plates and these to work?
This Motor Mount thread here answered my questions. Thanks!
Old Sep 29, 2016 | 09:51 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Now...to find someone that makes a tubular 700r4 cross member so I can better fit exhaust.
indebt
Dec 27, 2018 06:08 PM
thecaminator
Sep 29, 2016 07:43 PM
Shaz
Sep 27, 2016 02:24 PM
88Convertible
Sep 25, 2016 05:20 PM
