TPS and IAC Mounting
Old Dec 10, 2019 | 05:08 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Anyone know what the thread type and length of the screws that mount and secure the IAC and TPS sensors into the Throttle Body? I’m using a 102mm Nick Williams cable driven TB for my LS7 build. Thanks.
Old Dec 10, 2019 | 05:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TPS and IAC Mounting
Not 100% sure but I would start with a 6 or 7mm and go from there. Its likely metric and two trips to the hardware store.
Old Dec 10, 2019 | 05:53 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Headed to Home Depot now. I’ll just buy everything. 😂
Old Dec 10, 2019 | 06:17 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Honestly, you're better off. The bolts come in 2 packs for 60 cents. I'll buy $30 worth and the have a leftover stash of useless bolts. If there is an ACE or TSC take your parts there and try out the hardware. Their selection is 100× better than big box stores.
Old Dec 10, 2019 | 11:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I think my Nick Williams throttle body came with all the hardware. Are you sure the parts aren't just laying around somewhere?
Old Dec 11, 2019 | 07:51 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
TB came with engine as a package. So no bolt pack.
Old Dec 11, 2019 | 10:46 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
You were right. Found them. 🤦‍♂️
Old Dec 12, 2019 | 12:57 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
By the way, I have the same parts and I can tell you that the throttle cable is going to block access to the PCV port on the throttle body. I had to abandon the hose and instead put an air filter on the cylinder head.
Sometimes I will hear a whistle, like a blow-off valve, when I let off the throttle after a hard pull. I'm not sure if it's crankcase pressure relieving, or if it's the IAC making noise, or maybe noise through the hole I drilled in the throttle body. Either way it concerns me a bit and I'm considering using a vacuum pump, but it's so dang expensive!
Project 3.4 Camaro
Aug 11, 2011 10:32 AM
94fourdoor
Jun 4, 2011 01:22 PM
jcpegg
Pacific Region
Aug 15, 2005 06:33 PM
v8nate92RS
May 19, 2004 02:50 PM
camaro_V6_Tuner
Mar 27, 2004 11:40 PM
