Harness delete
Old Sep 18, 2022 | 10:20 AM
86TA6.0LQ4's Avatar
Car: 86 Trans Am
Engine: 6.0 lq4 (carbureted)
Harness delete
Hello everybody I Have a few questions about removing wires that are not needed from my 86 Trans Am I installed a LQ4 from a 2003 Yukon Denali it is also carbureted. Well I should say was Carbureted I now have a holly sniper EFI not yet installed
But my main question was how to clean up the engine bay and remove wire harnesses I no longer need?
Old Sep 19, 2022 | 07:51 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Harness delete
Everyone's swap is different so my best advice is to read the stickies above on wiring. You'll will be able to determine what circuits are no longer needed for your specific swap. Basically, you will reuse a lot of the wiring from the C100 firewall block, and you'll likely get rid of most of the engine control wires that route through the fender.
Old Sep 19, 2022 | 08:20 AM
86TA6.0LQ4's Avatar
Car: 86 Trans Am
Re: Harness delete
Thanks for reaching out. Could you be more specific or be willing to help?
Old Sep 19, 2022 | 06:27 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: Harness delete
Ford Blue... Nice touch.
Anyway, the first thing I'd do is figure out which components you AREN'T going to use (injectors, rear O2 sensors, etc.), mark them, then strip off the wire loom and take them out.
Pocket has a few really great threads about customizing LS/ LT wiring harnesses to fit our cars.
Last of all, why in God's name do you want to use a Sniper kit when the LS engines come with superior fuel injection from the factory?
Everyone I've ever met who had a Sniper had problems with it.
I'd go to the junkyard, grab the intake/ injectors/ harness/ PCM off of a wrecked Silverado before I'd ever spend a penny on a Sniper, but that's just me.
Old Sep 19, 2022 | 10:52 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: Harness delete
Amen to that brotha!
Old Sep 19, 2022 | 11:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Harness delete
Here are the threads that people generally reference, in the order they were created. My notes will save you gobs of reading, just jump to the relevant posts.
Sep 2009: How to prep a 3rd gen harness
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Part I of the wiring guide. Stripping and prepping stock 3rd gen harness for integration with an LS engine swap. Key posts #1-3, 25. The rest is Q&A.
Oct 2009: LS1 harness start to finish
https://www.thirdgen.org/forums/ltx-...rt-finish.html
Part II of the wiring guide. Building a custom LS1 harness. Key posts #1-7, 17. The rest is Q&A.
Nov 2009: Additional swap information
https://www.thirdgen.org/forums/ltx-...formation.html
Pinouts of C100 and C207 for various years. Simplified wiring diagrams of LS1 engine subsystems.
Mar 2010: LS1 harness revisited
https://www.thirdgen.org/forums/ltx-...revisited.html
An abridged overview of a "plug & play" harness from beginning to end. Example based on LS1/T56 swap into 89 GTA. Key posts #1, 2.
May 2010: Connector ID, PN and interchanges
https://www.thirdgen.org/forums/ltx-...erchanges.html
Photos and part numbers of some electrical connectors common to LS1 swaps. Suggested tools in post #60.
Old Sep 19, 2022 | 11:20 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Harness delete
And this is the mac daddy thread for electrical connectors with LS swaps,
https://www.thirdgen.org/forums/ltx-...lectrical.html
Old Sep 19, 2022 | 11:23 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Harness delete
This is how most of us do it that work on our own cars, we get hands on with it. Took me a long time to realize that all the planning and talk in the world won't get you as far as holding stuff in your hands. Go to something you don't need and take out the wires. Repeat until you're down to just stuff you still need. That's mostly just wiring for dash gauges and starter motor, maybe some other things.
Old Oct 11, 2022 | 03:31 PM
86TA6.0LQ4's Avatar
Car: 86 Trans Am
Re: Harness delete
ok thanks for that. Lol ford blue wasn’t thinking of that blue is my favorite color.
Actually I’m new to the LS swap had this car 16 years and my friends was like let’s LS swap our cars and was like ok.
I’m on a super budget and not too much swap knowledge so I went the carbureted route. I didn’t have luck with a good carb so I decided to buy the sniper.
Old Oct 15, 2022 | 02:37 PM
86TA6.0LQ4's Avatar
Car: 86 Trans Am
Re: 90 RS-Z 5.3T build
So I got $600 to spend right.
I have 4 header bolts broken off-shop charges $20 to remove each broken bolt.
Since I have to take my (317)heads off and take them to the shop, I have a couple more questions for you.
What upgrades would you consider?
Different heads or get cam and spring the 317s?
What would you do in my position using the lq4/sniper and $600 spare bucks? Not counting getting bolts removed.
Old Oct 15, 2022 | 02:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Smartest thing you can do is sell the Sniper intake. They're awful. Then do a cam swap.
Old Oct 15, 2022 | 03:46 PM
vorteciroc's Avatar
Top Answer: 1
Sniper Intake Manifold?
Old Nov 18, 2022 | 05:59 PM
Engine: TBI 305
First of all, get rid of the damn Sniper. I'd let you know my true opinion of it, but I'd probably get banned for violating community standards.
Get rid of the 317 heads and get some 243/ 799 heads. Thank me later.
Old Nov 18, 2022 | 06:11 PM
vorteciroc's Avatar
Top Answer: 1
There is definitely some Power increase from the smaller Combustion Chamber of the 243-Design Heads...
But the 317-Design Heads are essentially identical, other than a larger Combustion Chamber.
I do not feel going from a 317 Head to 243 Head is worth the swap (just a small Power increase from a small Static Compression increase)...
However a Ported 243 Head or Aftermarket 243 Head, would be worth the swap (a more significant Power increase).
Old Nov 19, 2022 | 12:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Go ahead and keep discussing but I'm going to move this guy's question and related replies to a new thread and get it out of Swappers build thread.
Edit: Posts moved.
85SS/85GN
Exterior Parts for Sale
Mar 23, 2018 06:58 PM
*84TA
Sep 9, 2010 10:24 AM
red/white04
Members Camaros
23
Aug 23, 2010 06:48 PM
85 T/A WS6
Pacific Northwest Region
Sep 24, 2001 05:24 PM
