cold air intake
Old Oct 13, 2025 | 03:31 PM
upstateRich's Avatar
Car: 1989 Firebird
Engine: 2001 5.7 LS1
cold air intake
Looking for a recommendation on a cold air intake for a LS1 using a 5 pin MAP Sensor
Old Oct 14, 2025 | 08:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: cold air intake
Make your own if you can. I had some 4" spectre aluminum tubing tig welded together with their MAF sensor welded in. You can get all kinds of bends. If you don't want to be that fancy you can buy rubber elbows from various places online, stick a tube in (Spectre makes one with the MAP mount welded in) and add a filter of your choice.
Old Oct 14, 2025 | 10:09 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: cold air intake
Shifty is right - these are pretty easy to fabricate on your own.
Spectre's website shows all the different pieces that are available - there's a ton:
https://www.spectreperformance.com/c...Kh58Xx6jTrxSZ1
here's a picture of one i made using their pieces on my old '72 camaro
Old Oct 14, 2025 | 09:20 PM
ULTM8Z's Avatar
Re: cold air intake
Just don't put the filter off to the side of the engine bay. That's not cold air.
The filter end needs to get air from completely outside the engine bay.
Old Oct 14, 2025 | 10:35 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: cold air intake
the MAP is mounted anywhere on the actual intake manifold.
The MAF needs to be in the intake pipe.
IF you have a radical cam, and are SD tuned, wire in an LS1 AIT and put that into the intake tube, or behind the throttle body in the intake manifold.
Old Oct 17, 2025 | 05:47 AM
FreyaLinton's Avatar
Re: cold air intake
Have you found it?
Spoiler
Old Oct 17, 2025 | 12:39 PM
Car: 1989 Firebird
Re: cold air intake
Originally Posted by FreyaLinton
Have you found it?
Not yet I am going to put the Radiator and fans in first and then take some measurements but I think that I will be going with Spectreperformance I called them and they are great to talk with
Rich
Old Oct 17, 2025 | 12:40 PM
Car: 1989 Firebird
Re: cold air intake
Thanks I think that I will be going with this company
Old Oct 18, 2025 | 06:56 AM
Pocket's Avatar
Car: 91 Trans Am
Re: cold air intake
I keep a few cheapo silverado intakes in stock like this. Use it like a parts kit, not a direct fit part. Throw the filters away as they're huge and terrible. Buy generic K&N 4" for $30
Cut the mounting tabs off and polish the areas after. Mix/match couplers. Buy better worm clamps from lowes (dryer vents), they're much tougher than the chinesium ones
Can make some really nice intakes from those kits for not much money
Amazon Amazon
These are all based on those cheapo kits
Old Oct 18, 2025 | 12:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: cold air intake
I went with siliconeinntakes.com. Got everything but the filter there.
ChevyCamaro1990
Apr 8, 2009 03:32 PM
thebirdsonfire
Sep 24, 2007 12:42 PM
kevo2k6
Mar 18, 2004 09:05 PM
91FIREBIRDGT
Feb 2, 2003 09:33 PM
