new rims and a drop - FULL pics!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
once i get the car washed/waxed and take some pics in the sunlight ill post up the full shots.
the rims are custom painted c5 vette magnesium rims (very light!) 17" up front 18" out back, the front springs are dropzone 1.75" and the rears are cut stock springs (1.75 coils cut), i may remove the isolators as well as it's not as low in the back as i'd like. i will say, it is LOW, but its a weekend car so thats alright!
teaser pics:
teaser pics:
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: new rims and a drop - teaser pics!
It looks good, All you need to do is buff and cut that thing, It has alot of orange peel
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
looks like it will be no fun to drive. It would hit every bump.
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Damm those rims are clean, any other pics?
Tony.
Tony.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
rims look interesting, would like to see a full side profile. oh and good luck trying to drive that thing!
COTM Editor
The front LCA has got to be sitting on the bumpstop... Looks cool, but is not functional at all.
What's custom painted about the rims? The N73 mag wheels always came in gunmetal ?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i'll have some full car shots up soon, the car is halfway through a color-sanding right now!
while the car is low, it's not my dd, so as long as i take it easy going in/out of parking lots it's not too bad, the longtubes and spohn cross member made it a pain to drive at stock height so there's not as big of a change as you'd think. as for being on the bumpstops... its close, REALLY close
twin-turbo, the wheels are a bronze color, that is about twice as dark as the original bronze the magnesium wheels came in stock
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Damn you have horrible ground clearance! But I say it's worth it!
I can't believe that those wheels have evaded my knowledge for so long, care to give all the details on them i.e. size, width, offset, weight, tire sizes.
I can't believe that those wheels have evaded my knowledge for so long, care to give all the details on them i.e. size, width, offset, weight, tire sizes. Thread Starter
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
they are standard c5 (non-z06) wheel sizes and offsets, 17x8.5 up front, 18x9.5 out back with 56mm offset, backspacing i dont know but i use 1.75" spacers up front and 2" out back
as for weight they are 17.x each front wheels, and 20 or 21 each rear wheel, i saved 8 lbs per wheel over my c5 chrome wheels
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yeah i will admit its WAY to low to dd, but the roads are decent enough around here that its not a problem for a car that gets driven once or twice a month maybe. i though it would be worse to drive than it is. new pics are coming you guys i promise, just got a new garage i've been setting up and have been real busy with that!
Car: 92 Camaro Rs.R
Transmission: wc t-5
my project car sitts that low to, and shes my dd
u get used to it, im touching bumps up front and the real is perfict, im thinken i might bring the front back up about half an inch, i just love the racing stance and look of sitting real low
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Those are my old wheels. Im glad your happy with them. I pmed you on ls1 tech after they were delivered to you asking how everything went but never got a reply.
I would like to see a side shot of the car also. I always wanted to put those wheels on my iroc but always had too much other stuff to do.
BTW guys those wheels are VERY rare here are a couple pics of them on my corvettes. I redid them b/c I bought 3 from a friend who broke one when he hit a curb then bought a replacement wheel off ebay to make it a complete set. They are like 300-500 per wheel, and the major thing is they are SUPER light as in like only 14 pounds each.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well I meant to color sand the car over break but it didn't get done so i'll throw up some pics that show the whole car, not perfect but better, the orange peel REALLY pisses me off, i need to sand it out. first pic is my favorite
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: new rims and a drop - FULL pics!
i am tempted too c how this rims would look on my car.. yet id like to see them powder coated silver like the zr1 rims.
Engine: 3.0L 2JZGE
Do the rims have a specific name to them?
Thanks. Tony.
Thanks. Tony.
Car: 88 IROC
If you are using spacers.. I would advise against them. I used wheel adaptors when I had y2k rims on my 87 vette. Spacers put unwanted load on the wheel studs and they can snap. Adaptors will prevent that from happening. Seems your front wheels need to come out just a tad bit more since they are too far inward. All in all the color looks great with your car!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i can't really bring the front wheels out more without them hitting the fenders...
Thank you! i think it's gonna really look good once i get the car sanded out
Engine: LB9, LB9
Oh yes you can, you just don't want to try. Pull or modify the liners, roll and slightly pull the fenders and a little hammering to the top of the wheel well, and maybe a little pounding on the battery tray (depending on your tire height) will get you all the fender clearance you could ever want.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
Linson
Aug 21, 2015 02:12 PM
the clear was the only thing i didn't get right when i sprayed the car
