Anyone going to Club Clash tonight?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
There was talk earlier of the new club showing up out there. Have you decided to do it?
I'll be racing with my old club, Heavy Metal Racing. If your club decides not to do it, you're welcome to put a "K" behind your number and race with us.
My son will be racing the Camaro, I'll be in the '57. Hopefully I've got my cam and fuel change issues sorted out now.
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
I wish I was gonna be there but still not done with the motor, now I've got a header problem seems that SLP's and AFR angle plugs don't mix so now I'm looking for a set of Hooker long tubes.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by 91RamAir Formula
..now I've got a header problem seems that SLP's and AFR angle plugs don't mix...
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I was planning to go but won't be getting off work till 5
Engine: LS1/LQ4
Don't let that stop you. Although the gates open at 3, as long as you get there before 6 you'll get 2 time trials. Get there after 6, you'll get one. Eliminations rarely start by 7.
Note that I'm not there yet.
On my way, though!
On my way, though!
1 Post
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Originally Posted by V8Rumble
Crap, DON'T tell me that, I've just bought my AFRs after people said that they did work together!!
OK, that makes me feel a bit better - although I'm going to pay special attention to that when I finally start bolting my combo together... And yeah, I made a point of requesting the L98 angle plug version of the heads, along with provisions for the coolant temp sensor & the ability to use either centerbolt or perimeter-bolt valve covers...
But thank you for confirming that your SLP headers work with the heads, as those are the same headers that I'm using.
(Sorry, didn't mean to hijack the thread!)
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
Yea I got regular angle plug heads so if anyone has hooker long tubes they want to get rid of let me know. or I'll trade my slp's
Yeah, I wanted to ask - how did it go last night??
Engine: LS1/LQ4
Well, a mix - again.
There were a bunch of cars out, like there usually is. Time trials didn't finish until almost 8 p.m., and first round took until almost 10. My TT runs were within a few thousandths, which would be great except the air improved 300' between them and the 2nd was the slower. The Camaro was slow first run and quick the 2nd, so we weren't sure what to put on, finally decided to go with the 2nd run. As it turned out, we both went out 1st round, in opposite ways - I was treed (again) and broke out trying, he put a light on the other lane but hit the brakes too hard and let them around.
No racing next weekend (Night of Fire & Thunder), back to ET series on the 26th, and next Club Clash June 2nd.
buckeyecelt
09-24-2015 05:50 AM
