Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Can I pull a sub 13.5??
Old 07-22-2003, 05:06 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Currently my 1990 IrocZ is capable of a 14.3x... I was able to pull a 14.51 with a 1.99 60' but I have achieved a 1.88 60' in the past... so 14.3x is possible (with good driving).
The car has only these mods: !airboxes w/ k&ns, TB foil, Accel 8mm wires cap&rotor, a mildly worked 700R4 with stock stall and energy mount, and KYB GR2's front and back.
That is it! No breathment at all as far as the TPI system and exhaust is concerned.
So, with a ported plenum, as&m ltr's, ported edelbrock base, headers & a catback am I thinking correctly a sub 13.5 or even a high 13.5x is possible?
If not, will 1.6 rockers added to the mod list get me there?
Just wondering, as this is the first stage of my mod plans before I do something about a new or rebuilt 350 powerplant.
Old 07-22-2003, 09:16 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
this probably belongs more in the tech/general engine board, but oh well...
if i were you, and i was planning on a 350 swap in the future, i'd stay away from buying 305 specific parts. I'd go with the rockers first. Personally, tpi isn't my thing, so i can't put in any positive comments there...
i'd almost tell you to worry less about the engine and more about the suspension, drop the 60ft times with lca's and relocation brackets, look at torque arms, things like that are going to be just as important with a 305 as a stout 350...why throw money at something you plan to get rid of?
Old 07-23-2003, 04:09 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It IS a 350.
Old 07-23-2003, 01:05 PM
Engine: V8
hmm, skimmed over that when i saw the new or rebuilt 350 powerplant statement...my bad...
if you intend on sticking with tpi, go ***** to the wall man, i don't claim to know what i'm talking about when it comes to tpi, but i think i the consensus of the tpi board is that you should start with the lower intake, the as&m ltr's seem to be pretty popular and port the plenum...based on what you had planned, you know that already.
do you have a chip in the car? i was, at one time going to run an lt1 intake on my car, don't waste your time with superchips or hypertech if you haven't already, get one custom burned by someone that knows everything about your car, or buy the equipment and learn to do it yourself.
there's a member named jfreeman or something similar, he's got an 85, probably a little less weight than you, and as your probably know, 85's had a ****ty computer, the old style hei dist (not the divorced coil you have), and he had a 305. he's running 13.7 with headers, a new cat, 3.42 posi, underdrive pulleys, and a pro-built 700r4 with a 2800 stall...you shouldn't have any problems going 13.5, you've got a much more potent engine...
Old 07-24-2003, 10:03 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
I agree with every thing he said. A better/higher stall converter
will if chosen properly might get you .30 t0 .40ths off your present
e.t.s.1.8x are pretty good 60 ft times.I believe your going to need more hp to beat that number unless you are still spinning.But a stall or more gear should help both.
83 Crossfire TA
01-03-2016 01:26 PM
wigmobile
09-17-2015 03:38 PM
Amillionoh7
09-11-2015 11:36 AM
sylentnite
09-09-2015 02:55 PM
2012sergen11
Interior Parts Wanted
09-07-2015 11:37 AM
Quick Reply: Can I pull a sub 13.5??
