Another l03
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Another l03
1992 Camaro RS
56,000 miles.. everything is in good shape
Edelbrock open element
3" catback exhaust
High flow catalytic converter
Flowmaster 80 series muffler
I'm getting a 3.42 or 3.73 gear this week.
So estimate i have a 3.42
Btw I live in Southern Ohio
So what do you think i will run?
One Question.. Why does the lo3 range from a 15.3 to a 16.5 when i see peoples times-slips? Does the driver matter that much?
3" catback exhaust
Car: '88 IROC-Z medium orange metallic
I ran 15.88 with 1.96 60ft with my L03 before I ripped it out. Had open element, a/c delete, flowmaster catback, no cat, MSD ignition and 3.27 9 bolt.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Mid 15's at best. Expect low 16s on your first few runs.
Originally posted by M1tch
Thats an aweful good 60' time to be running a 15.88 isnt it?
Car: 89 RS
Transmission: th350
I have seen alot worse. His car would cut 1.8 60s and at about half track it would start detanating real bad and i think he ended up running a high 16.
He ended up geting fed up with the motor and stomped it in neutral till it threw 3 rods.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Dude this 96' Mustang GT keeps trying to race me at my school. He said he runs 15.3's. He has a cheap exhaust, and a shift kit.
He runs the **** out of it. 120,000 miles.
I'm ordering a 3.42 gear soon and in a few months im getting headers. What should i do? hah
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I would say just for starters get the 3.42's, aluminum D.S.,Ultimate tbi mods and some 1.6 rockers for a little extra cheap kick.Just these 4 will make a noticable differance if your car is in a good state of tune.(plugs,wires,air filter,bla bla bla.)
Car: ws6
Engine: ls1
Transmission: m6
Car: ws6
Engine: ls1
Transmission: m6
with full exhaust, open element, 3.42, advanced timing.. you dont think its possible for low 15's?
ehhh MAYBE 15.3's. Thats cutting it close.
I don't know exatcly how much power 1.6's give but I felt a very noticable improvement in all around power.
Car: ws6
Engine: ls1
Transmission: m6
Originally posted by TonyC
Spray it or swap in a 350
Car: A Camaro
Engine: Weak
Transmission: Weaker
Originally posted by 89IrocZ350TPI
Id stay away from the spray if you dont have any experience with it. Replacing that 305 with a 350 is your best bet. There is no replacement for displacement.
Car: ws6
Engine: ls1
Transmission: m6
Id definitly give the 350 some thought. The avg new car accoring to Motor Trend runs a 15.7, and the avg sports car runs a 14.5. Those numbers are probably alittle off but they are close. With a good 350 you will get more bang for your buck, than you will with that 305.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
im a 17 year old teeanger with no money lol.. My dad wouldnt let me do it anyways.. but im keepin the car for a while.. so the mods i do now arent engine mods.. im going to change the rear end and stuff
Car: ws6
Engine: ls1
Transmission: m6
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
what should i buy first, 1.6 rockers or headers?
Btw whats some good headers that wont leak? thats a decent price?
Car: ws6
Engine: ls1
Transmission: m6
Ive had Edelbrock TES headers on both of my cars. Work great no leaks or anything. With those horrible l03 exhaust manifolds you will be VERY surprised how much power they will had.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
dewey on the l03 boards ran a mid 14 with a full exhaust, open element and chip burning. That's enough to beat a '96 GT
L03s are horribly tuned from the factory. And all thirdgens have crappy exhaust manifold design.
Full Catback and a good tune will work well with ur 305.
If it helps, my father has a 318 truck, also TBI, and here are some tricks we did.
TBI spacer
Headers
Y-pipe
Catback with glasspack
4.11 gears
Shift kit
Stock aircleaner with oversize filter and holes drilled in it
2800 stall
RADIAL tires
100k miles
Truck weights 3900 lbs and run 13.6-13.7 all day long.
TBI spacer
Headers
Y-pipe
4.11 gears
Shift kit
2800 stall
RADIAL tires
100k miles
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have my 3.42 gear now what should i shoot for? The guy installing my gear is also advancing my timing.
Headers or 1.6 rockers?
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
Headers, get the Y-pipe too. The only thing i don't really like is that the Y-pipe exits as a 2.5", I wish it was 3".
When I got mine (hedman), the directions told me to lift the engine up 2" and a buncha other BS, I just took off the drivers side valve cover and slipped them in, very easy compared to my friend's '72 Cutlass. Took me 1 hour to take off the manifolds and put the headers in, I kid you not, lol.
Headers/ypipe, good 3" catback, open air element, posi/gears, shift kit, servo, 1.6rr's. Gonna be about as good as it'll get with TBI withoug spending a bunch of money and getting into the motor
Car: ws6
Engine: ls1
Transmission: m6
Id go with the headers first.
Car: A Camaro
Engine: Weak
It's actually really easy to swap out rockers, just pull the valve covers, remove nut and whammy. The hardest part is re-setting the valve lash, but that's pretty well documented on this site. Make sure to rotate the engine through it's full circle too to check for clearance on all the pushrods.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
One last question to people who have ran their l03 with a 700r4 at the strip..
Whats the best way to run it? Shift from 1st-2nd-D?
If so what rpm range do you shift at? When i do it manually i shift out of 1st at 4500, then 2nd at around 4500 also. (i understand it loses power at 4,000)
Car: ws6
Engine: ls1
Transmission: m6
Dont shift in manually. The auto will shift in order to get the most out of every gear. When I shifted manually I ran a 13.8, then I let the auto do the work and then I ran a 13.5.
Car: 1976 Camaro LT
Transmission: TH350
if you wanna gear the car, do it all the way. look at some 4.10's. they will completely change the way your car reacts and contrary to popular belief the little bit of extra cruising RPM does not cost any substancial amount of engine life or mileage.
as far as shifting the car, most thirdgen factory tachs are about 300ish RPM optimistic. i found with my old 91 RS i got the best results shifting it when the tach was at 5000rpm. it was usually worth about 3 tenths over letting it shift on its own.
have you done the free mods yet?
i got 89.xx trap speeds with full exhaust and free mods from my 91. they are easy and very effective. adding about 6-8degrees advance to the timing will help a ton out of the hole.
traction is the key to ET. look for a set of boxed control arms or a used aftermarket torque arm to help the car get out of the hole woudl be even better.
good luck
good luck
Car: 1976 Camaro LT
Transmission: TH350
i have seen stock TBI cars shift themselves as low as 3800 and 4600 at the highest. with less torque avialble TBI reacts a lot more to raising the shift point a few hundred RPM than a TPI car would.
Car: 1992 Camaro RS
Engine: 3.1 liter(its slow)
