Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How fast should my combo be?
Old Mar 13, 2007 | 11:02 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I know, it's asked all the time but I'm a little curious. What stall speed should I get with this combo as I still have the stocker?
Old Mar 13, 2007 | 11:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think u would want more gear...possibly 3.73's to best match that combo
that seems to be a good combination, alot of ppl doing it. with those good heads and 355 HR with that cam, with good tune, i can see it making 350whp fairly easily, possibly a shade more.. thats usually good for lower 12's with good hook. 12.3-12.4's wouldnt be too shabby. mph should be 112-113 or so.
as far a stall? i'd go 3200 or so, especially if you want to street drive it alot. 3400-3600 would be as high as i'd go and would be best for maximum 1/4 mile stats with slightly deeper gears like 3.42 or 3.73
Old Mar 14, 2007 | 03:03 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3600 stall and 3.73s or 4.10s with 28" slicks would be optimal
Old Mar 14, 2007 | 03:09 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I think there is a ton of potential in that motor. With a good tune you should be at least at around the 12.0/114 mark +/- dendending on the elevation, weight, etc. but you're going to need a good converter (go big! at least 3500 IMI) and sticky tires.
Good luck and report back how you did!
Trevor
Old Mar 14, 2007 | 09:14 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Will that high of a stall be good for a somewhat daily driver? I won't be driving it everyday but as much as possible.
I'm excited about getting this motor in, the block will be dropped off Friday and my heads will be here Thursday. It sure will beat my previous 15.4 @88mph with my LB9.
3.73's are on the list but not for awhile as I have deleted my car budget with this build. I need to pick up the converter soon but gears will be in probably this winter.
Old Mar 14, 2007 | 10:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if you get a good converter and keep the lockup style, then 3600 wouldnt be too bad for a daily driver. just geta trans cooler to be safe and those are pretty cheap.
when u get a tune or do tuning, just set the TCC lockup speeds lower so the converter locks earlier while under little throttle input. this will help keep the converter locked at low speeds to help keep the tranny cool and reduce wear. slow speeds up a hill with the converter open is kinda annoying...so make it lock earlier
Old Mar 14, 2007 | 12:56 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
What would happen with a 2,400 or a 2,800? It's my first motor with that much power and I've never picked a converter and don't know how it will act.
Old Mar 14, 2007 | 01:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At the track it'll be lazy off the line with the lower stall (2800).
Old Mar 14, 2007 | 01:15 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'll only really see the track at get togethers and not looking for the absolute best time. I would just like a good compromize between the street and track, a little easier on the street though. How much of a time difference are we looking at between say a 2400-2800 and a 3200 at the track and how will they act on the street? Thanks.
Old Mar 14, 2007 | 01:17 PM
five7kid's Avatar
As much as a few tenths.
Old Mar 14, 2007 | 02:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah could be a few tenths, but i think a 3200 is a great compromise. 3600 would be best for strip ability but fine on the street for daily driving. recommend a tranny cooler tho if you do alot of hills in your area.
2800 works great for my stock L98... and would be somewhat lazy in your car but tonz better over stock. i'd use this if you really dont care for 1/4 mile and just want some better driveability on the street with just alittle bit of stall for some fun on the street as well. it woudl be primarily only a street car that needs to be tame and driven alot.
thats why i think a 3200 would be a great compromise. possibly even a 3400.
Old Mar 14, 2007 | 02:54 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'l probable shoot for a 3000-3200 then.
Old Mar 14, 2007 | 04:08 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Just out of curiosity, What would it do with the stock converter? I know I'm not gonna use it but I was wondering what the stocker would feel like.
Old Mar 14, 2007 | 04:18 PM
xpndbl3's Avatar
Car: 1984 Z28
motor wouldn't want to idle or run at all with a stock 1200 rpm stall
Old Mar 14, 2007 | 04:29 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Haha, didn't think so.
Old Mar 14, 2007 | 05:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if it did idle good and had some low end to get thru that soggy spot before the cam kicks in, it would launch softly like a stock car and i'd expect only high 1.8 60 foots. with a good stall, it will be 1.6x 60 foots
with stock converter i can see low 13's to high 12's depending. a stall jump from 1200 stock to 3400-3600 is really a huge difference and you'll probly see half second drop. i seen about that with my car, from my estimates, and i didnt go up as high in stall speed. 1200ish to 2800 with a stock L98.
definately try to stay around 3200 or higher
Old Mar 14, 2007 | 05:13 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
wow...you sound like my combo
i am VERY interested what you are going to be running i know i should use a higher stall but what can i say? im a cheapskate i got this stall converter as a deal....
Last edited by 89formula350b2l; Mar 14, 2007 at 05:17 PM. Reason: Automerged Doublepost
Old Mar 14, 2007 | 05:41 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
The engine should be in the next few weeks and after break in I will get it broken in and get to the track and see how it does and post up. We're having a Norcal vs. Socal June 2nd so I need to have it tuned and reay by then.
Old Mar 14, 2007 | 07:57 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
For reference:
With a 2800 converter and 3.73s my best was a 1.75 & 12.10 @ 114
With a 3500 converter and 3.73s my best was a 1.71 & 11.99 @ 114
With a 4200 converter and 3.73s my best was a 1.63 & 11.72 @ 115
With a 4200 converter and 3.08s my best was a 1.71 & 11.92 @ 114
These times are not corrected. The differences are bigger corrected for DA.
Old Mar 15, 2007 | 11:01 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'm going to try to get a 3200 vigilante in the next month or so. Hopefully soon though.
Old Mar 15, 2007 | 04:32 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Good Choice! Precision makes great converters.There 3200 is prolly more a 3500 anyways lol.The steep first gear of your 700R4 will help your lack of gear.You'll definatley have you a low 12/high 11 sec car.Good luck.
Old Mar 15, 2007 | 05:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it will help off the line but i think he will be on the low side of the rpms at the line. especially if using tires bigger than 26 inch. my friends 3.70 geared car crosses the line at like 5300rpms and 99mph... but theoretically that should be more like 105mph or so based on the calculators.
and by the way, thats a hell of a quick bolt on SS you got there.. one of the fastest times i've ever seen out of a SS
Old Mar 15, 2007 | 06:55 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Yep i agree,was just saying he wont have a turd of the line with the 3.23s lol
Thanks! Yep its a good running sob.It went 12.30s@112 with just a lid and prostars.Gears,cutout,headers,ported tb it went the 11.96@117 .Damn ls1s lol.I'll have one in my car in the next few years.Its the wifes car BTW
Old Mar 15, 2007 | 08:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
haha those are great times man... my buddies auto car needed a MS3 cam to do 11.78 at 118
Old Mar 16, 2007 | 03:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
do you have that red z28 with the license plate that says 11secz28 something? i think i have seen you at richmond dragway and i talked to you once before.....awesome looking car if its urs!!
Old Mar 16, 2007 | 04:53 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Yep it was probably me.Thanks.I'm at Richmond Dragway ALOT. My plates say 10SEC 91 now.I actually lived in Stafford for a couple of years..99-01 Gimme a shout if you see me out at the dragstrip this year.
Old Mar 17, 2007 | 02:05 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i know ls1's are a whole different ball game but a buddy of mine went from a stock auto 02 WS6 and ran 13.35@103, to 12.56@107going from stock stall and 3.23's to 3600 stall and 3.73's, headers and 3" TD's got him to 12.24@109, on DR's mind you. hes going for a tune this week and could possibly dip into the 11's with just stall, gears and exhaust, also this car is 100% stock body/interior with no reduction (his only car)
Old Mar 17, 2007 | 01:25 PM
Car: 92 Camaro
Axle/Gears: S60 373
i am planning to be there late april timeframe if you see a white 89 formula 350 with both headlights sticking up thats me....license plate GME OVA
Old Apr 24, 2007 | 10:07 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Re: How fast should my combo be?
What about this cam? I'm thinking of using it instead.
280XFI HR13
http://store.summitracing.com/partde...8&autoview=sku
Old Apr 24, 2007 | 10:50 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hehehehehe. Seeing as we may be lining up against each other I hate to give out advice. Anyways I think you are light on the injectors. I would go with SVO 30 pounders.
With my combo I'm running 80% duty cycle with my SVO 30 pounders at 6000+ rpm. Sounds like we should have a good race. No comment on the cam.
Old Apr 25, 2007 | 10:26 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Haha, I just hope I can get this thing running by then. I may tow it down your way for a dyno tune 1st.
Old Apr 26, 2007 | 07:55 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
i think the 3200 converter was a good choice, the stock converter in my 1991 ford ranger stalls around 3000(behind 140hp). it'll be nice to drive around town.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
customblackbird
Oct 1, 2015 04:30 PM
roysatikas
Sep 22, 2015 08:15 PM
